Satoh S650g Hydraulic problems
/ Satoh S650g Hydraulic problems #1
nys650g
Dansville NY
Satoh S650G
I was using this tractor 3pt and loader worked fine parked it then nothing worked. I checked the obvious, fluid, leaks etc all was fine. So i check the block at the pump and sure enough it was stripped. Switched it out for lovejoy connectors and still nothing. New fluid and filter done . Any clues im lost? I was able to torn pump by hand, so is pump bad?
/ Satoh S650g Hydraulic problems #2
You probably need to determine pressure and flow out of the pump. The fact that it turns by hand doesn't necessarily mean it is working.
Rotating Brush Sweeper Tractor Attachment (A59228)
Rotating Brush...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2009 Honda Civic Sedan (A59231)
2009 Honda Civic...
Caterpillar 320 (A60462)
Caterpillar 320...
2003 Coachmen Catalina Sport 220RK Class C Motorhome (A59231)
2003 Coachmen...
