Satoh/Mitsubishi temp. sensor
/ Satoh/Mitsubishi temp. sensor #1
rayford52
satoh buck
I just bought an old Satoh buck, overall it's pretty good but the previous owner put a different temperature sender on it that uses the copper line thing wrapped in a wire type housing, I'd like to put the original sender back in because the gauge they put it doesn't work. Does anyone happen to know the part number? thanks. Vernon.
/ Satoh/Mitsubishi temp. sensor #2
Why does it overly matter? Do you normally overheat your equipment?
You do have the correct radiator cap right?
/ Satoh/Mitsubishi temp. sensor #3
I replaced the "idiot light" on my Mitsubishi with a gauge as I wanted to actually see how hot it ran. The light was controlled by a 111 degree Celsius sensor. If you want the "real thing" check in with Valley Power as they'll probably be able to tell you exactly what you need. In my experience they'll even stock it. They are located in Roanoke, VA but they do ship.
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2014 LEVIATHAN  T-BELT TRAILER (A67714)
2014 LEVIATHAN...
PALLET OF MISC JACKS AND JACK STANDS (A67714)
PALLET OF MISC...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
