satoh bull electrical problem
/ satoh bull electrical problem #1
goose33
sweet home, Oregon
satoh bull/ 6300
Hi everyone. I am new to the group. I have a satoh bull 6300. It has been a great little tractor. I went to use it the other day and I had no power to the dash. I thought I had a dead battery. I charged the battery and still nothing. I have power to the starter, alternater, and the switch. I have checked the fuses and wiring. Everything is ok. I did find that the voltage regulator had a broken wire but I repaired it. Not sure where to go from here. Any help would be greatly appreciated. Thank you in advance.
Thank you.. I am going to see if I can find a regulator and new ignition.
/ satoh bull electrical problem #4
To eliminate switch problems squirt some WD40 into the key slot and wiggle the key a bit.
That action will dissolve hardened lubricants and renew the contacts.
/ satoh bull electrical problem #5
You might check all the electrical plugs and connections. Mine had a bunch of connectors that were brittle and literally crumbling. This could lead to corrosion on the connector pins.
Adams Tilt Trailer (A63688)
Adams Tilt Trailer...
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2024 Kubota SVL 75-3 (A64126)
2024 Kubota SVL...
