satoh beaver lift problem
/ satoh beaver lift problem #1
tdquarterranch
My hydraulics will lift the arms but when i push the lever forward to lower the will not go down. If i cut it off and pull back(like i am trying to lift the arms) the arms will go down, what could be causing this?
/ satoh beaver lift problem #2
Does the lift not come down at all, or just drops real slow?? I guess you tried adjusting the rockshaft valve?
/ satoh beaver lift problem #3
If the Sotah is like my Mitsu, under the seat is a kobby aluminum valve that when turned in one direction keeps the lift locked in the UP position.
Turning the other way allows the PTO to lower.
Hope that helps.
/ satoh beaver lift problem #4
Are you discussing the front end loader or the 3ph?
If the 3ph, kebo might well have the answer although the rockshaft valve knob should cut off all movement if it's closed (so the lower links (arms) shouldn't drop even when you do move the rockshaft lever). Can't hurt to open and close that knob a few times.
If the loader, it's probably the hydraulic valve.
However, always do the least intrusive work first. That means to check the hydraulic fluid level first. If the level is correct, change the hydraulic oil and filter (clean any screens in the system too). If that fixes the problem, great. If it doesn't fix the problem, then you'll need to decide if it's a problem you can troubleshoot or if you need to take it to a dealer.
tdquarterranch, you will need the tractor maintenance manual if you want to tackle the job. And I suggest you do not start tearing anything down until you confirm parts are available.
1996 Ford F-350 Pickup Truck (A64194)
1996 Ford F-350...
2 Row Cultivator (A64047)
2 Row Cultivator...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
Landhonor 8' x 6' Metal Shed (A66408)
Landhonor 8' x 6'...
60in Hydraulic Forks and Frame Skid Steer Attachment (A64553)
60in Hydraulic...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
