Sandy Drive project
/ Sandy Drive project
Tread, Google "soil cement", there's lots of data available. MikeD74T
That is essentially, what I am wanting to do. But, instead of portland cement, using a mix of PC, sand and small pebbles, which is what the Sakrete is. I may need to use more seeing as it isn't straight PC but has sand and pebbles mixed in it.
I have been up all night at work so I am going to sleep, I really can't think straight at the moment.
I do wonder if I do this, how will it hold up under very light traffic without having rebar of some other type of reinforcement in it.......:confused:
Tread
/ Sandy Drive project #22
That seems to have some promise to it, I will give them a call and see how much will be needed to do my 900-1000 ft of drive. Have you or anyone ever used this product or anything similiar to it?
Thanks,
Tread
I found more data about the product. If my interpretation is correct it will cost about $12-15/sq yard. I think that is more than concrete.
/ Sandy Drive project #23
Tread,
Have you confirmed that you can get all this concrete delivered to your site at minimal cost? I would think that would be the crux of this whole project. If you can get bags of it you may consider buying a tent like carport or something to put over the bags of concrete mix while you play with it.
If you can get multiple bags of the stuff and till it in it won't hurt your cause as you can always spread more sand on top when it breaks up to smooth it out right? Even cracked and broken up the big chunks and gravel in the base will help you. You could probably roll concrete reinforcing wire mesh or place rebar on top after you till but before you roll or tamp but that could come back to haunt you later and will obviously add cost.
/ Sandy Drive project #24
I just had another idea, You could roll out "driveway fabric" on the sand first and then put 4 inches or so of your concrete mix on top perhaps with the mesh or rebar in the middle. Wet and tamp or roll and you would be in good shape.
/ Sandy Drive project #25
"KennyV Re: Sandy Drive project"
"Like was said... you need a base to place the surface on... do you not have limestone or any other cheap base rock in your area?"
I had the impression that sand was the perfect base as once wet it provides 100% compaction.
Tread,
As of now, I have not confirmed that I can get it. My father has talked to him once to inquire about it and was told they do have one reject shipment but is in 3000 lbs bags. I don't think he has tried calling him back to get a confirmation. I know he got some once, years ago, but in normal 94 lbs bags. He used their forklift and was loading it up on a friends flat bed tractor trailer.
Right now I am trying to figure and make sure that I wouldn't be causing myself more work down the line, before I get the stuff. I mean if I get it and would be best to not use it then I would have to store it, and or dispose of it.
Call this pre-project planning and development......
Tread
Possibly mix into the mix when tilling what they use in concrete reinforcement, glass fiber. Not sure if it would help or not.... Just brainstorming.
Tread
I am not sure but if sand is the best, as far as 100% compaction, when wet then I definately have plenty of it
/ Sandy Drive project #29
Just running the numbers on this project for cubic yards of concrete needed for a layer 1 inch thick.
Measured in feet:
length X width X depth = cubic feet
divide by 27 to get cubic yards
1000ft X 24ft X .0833 = 1999.2 cubic feet
1999.2 / 27 = 74.04 cubic yards for a 1 inch layer.
Can you get enough Sakrete to put on the road to make a difference?
Could find out how much Sakrete you can get. Figure out how thick a layer that will be on the road, then buy a couple bags of Pre-Mixed concrete and run some tests on different ways to apply the mixture to the road and see which one works best or if it will work at all.
/ Sandy Drive project #30
Like Eddie said, the sackrette is not going to hold up. I don't think it will do you any good at all. The first time you drive over it, it will fall apart. I hate to be negative, but I think it would be a waste of time. Even with rebar in it and 6 inches thick, it will break up because there is no base under it. I think adding gravel and/or the stabilizer product would do a much better job. I think if you do add gravel, you will have to keep adding it as it will just gradually disappear in the sand. If you keep adding gravel, it will eventually build up and give you a base to work with.
Just another note, in my area "sand" is often used for backfill under roads. Sand in our area is not near as pure as what you have. The sand in my area would be like mixing clay in with what you have. When the moisture is just right, it will bond together very well and pack down really hard. The problem with your sand is that the grain size is all the same, it has nothing to bond with. If clay was mixed in with it, it mmight pack down well and then gravel could be added on top.
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
Caterpillar 320 (A60462)
Caterpillar 320...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A59230)
2012 Ford F-550...
