Same old story: Power Trac vs Ventrac
/ Same old story: Power Trac vs Ventrac #21
i am going to get smacked across the face, but seems like ya going pretty good overkill for 1/2 acre yard.
have you tried every filling the rear tires with fluid to get you some extra weight in the rear end, and get some better traction? weight in tires also helps some by getting COG (center of gravity) for the tractor a tad lower, so less chance of flipping it over on a hill.
swamping out rear tires for say R4 or R1 style tires that have ribs in them to grab the dirt, on a riding lawn mower is a tad overkill, and you will more likely get better luck with "tire chains" on rear tires.
the up hill battle you face is both, a light weight machine, and tires that will not give you much traction. and you will most likely face same issue no matter what machine you end up with.
granted 4x4 / MFWD will help, but overall fill tires up with some fluid, and see about chains for rear tires, maybe even wheel weights.
if the engine simply does not have enough HP to spin the tires in all condition (( you are loosing traction)) then its not a HP issue but traction issue.
BAH just forget some riding lawn mowers, you may need to get "wheel / rim spacers" do to not enough clearance :/ it might be possible to swap real wheels, so you get a wider mowing machine and give you enough inside clearance for chains. (( its all in the rims, and how much offset the rims have, that can allow for this))
Adding fluid to the rear tires only on a power track will probably get you WORSE traction for going uphill ;)
/ Same old story: Power Trac vs Ventrac #22
I would like to thank everyone who contributed to this thread, I just ordered a 425 with finish mower, rough cut mower, large bucket, snow blade and mini home. I have a couple off small hills, but mow 3 acres of lawn and 4 acres of field that has been cut and maintained the last 5 years. I'm getting older so the quick attach was very attractive to me, after muscling the 3 point hitch on my old JD. I'll keep you posted on me usage of the 425. Thanks again!
/ Same old story: Power Trac vs Ventrac #25
I wish I had the mini hoe. Been looking and thinking on wether to make one or buy one. If I made one the hardest part would be the linkage I think. I can only see so much of Power-Tracs when I zoom in on their picture. Now if someone had plans so we could use to make one that would be great.
2000 TEREX T560 CRANE TRUCK (A59905)
2000 TEREX T560...
UNUSED FUTURE ELECTRIC WET POLISHER (A60430)
UNUSED FUTURE...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A60429)
2022 CATERPILLAR...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
