SAME Mercury 85
/ SAME Mercury 85 #1
northcreek2624
Lake View,N.Y.(WNY)
KIOTI DK40(2002)) Jacobsen 628D AWD Turfcat
Hi folks,Wondering if someone might know a good source for Same graveyard parts.My son recently purchased a Mercury 85 4wd and I've noticed a couple of cracks in the front support casting,no doubt from a FEL incident some time ago.We will remove it and get it repaired but,replacing it is preferable.I located one in CA.but,at$1,700 + shipping to NY my son wanted to keep looking.Hope somebody can help...thanks,Mike.
/ SAME Mercury 85 #2
Thinking maybe this is weak link in these tractors went and looked at a 4 wheel drive same with loader recently and same part had damage to it . Tried to find bracket before considering purchase . But lot worse than just mount on this tractor it actually broke engine block bolt holes where it mounts wasnt told of this MINOR detail until drove 2 hours to see it . Good luck
/ SAME Mercury 85 #3
/ SAME Mercury 85 #4
You may be able to get the part from Farmtrac. They've picked up a line of Same built tractors. The name and model no. has been changed to Farmtracs. I've seen the 115 hp 4 wd. with cab on my dealers lot. He has one 95hp without cab and I think there's a 85hp there too. It looks a lot like to model you have.
/ SAME Mercury 85 #5
/ SAME Mercury 85 #6
If it's too weak anyways, you should consider welding your own from heavy sheetmetal.
1700 dollar is a rip-off, a local machine shop should be able to make you a stronger replacement for less....
/ SAME Mercury 85 #7
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
207923 (A63290)
207923 (A63290)
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
iDrive TDS-2010H...
