safety chain connetor
/ safety chain connetor #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I have a 2010 F150. The attachment points for the trailer safety chain is flat steel with a slot cut in it. the distance from the edge of the plate to the slot is deeper than most hooks. The slot itself is then not that wide. Can I use a shakle or something in the slot and connect the chain to that? I pull a 7000lb horse trailer and a 5000lb flat bed.
/ safety chain connetor #3
As long as the shackle is load rated you should be fine. I just use the hook on mine and shortened the chain, however my safety chains have deep hooks that clear the slot edge. They also have that spring flap closure thing.
Hope this helps
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
(5) Round Cornstalk Bales (A66408)
(5) Round...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
2002 Freightliner School Bus (A64194)
2002 Freightliner...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
