SAE-8 Banjo Fitting Autocad
   / SAE-8 Banjo Fitting Autocad
So here's a shot after profiling the radius a bit more, getting ready to begin the second port:
/forums/images/graemlins/smirk.gif
Then I used a center drill to mark the center of the first port sleeve, and drilled it with an 1/8", 1/4", .406", and .5" drills. The first three drills I drilled through to what will be the core of the banjo, but with the 1/2" drill I stopped at 1/2" depth to make a shoulder to stop the tubing.
The profile radiusing is almost impossible to get very smooth by hand. I just don't the proper trig calibration in my hands to CNC it manually. /forums/images/graemlins/smirk.gif The last thing you want to do is to cut too far, so I left it a little big. I will be cutting a similar radius profile at a right angle to this which will allow me to take some of the roughness out.
This shot shows the sleeve bore shoulder-stop for the tubing.
This is a larger view of the drilling setup.
And here's another long shot of the lathe at this setup. /forums/images/graemlins/smirk.gif
Next I will take the part out of the 4-jaw and set it up for the second port sleeve.
I forgot to take shots of cutting the second port, but of course that would have looked just about like the first port. I got kind of distracted because I had gotten impatient and fed the starting 1/8" drill too fast and snapped it off. Steel is pretty unforgiving of impatience. Anyway, it was just the very tip and I was able to drill past it with the through hole and then push it out with a drift punch (ie: I got lucky).
This shot shows the piece turned flat so I can face it, and drill the 3/4" through hole. I set the piece as flat in the chuck as I could get it, and then cut a clean face. Then center drilled the piece, drilled with an 1/8" starter drill, 1/4", 3/8" 1/2", 5/8", and finally a 3/4". I did a bit of deburring and here it is.
I took this one with the flash while it was cutting the 1/2" hole, you can see the chips peeling out as it spins. /forums/images/graemlins/smirk.gif
Here's a shot after finishing the 3/4" drill /forums/images/graemlins/smirk.gif
In this shot you can see that I decided to put some stubby bolts in the braze sleeves to spread out the chuck jaw pressure. With the violence of boring a 3/4" hole, I had to clamp down the chuck jaws real tight and it would have left deep impressions on the braze sleeve ends. This way they came out without a scratch.
This shot is a bit misleading. It looks like the profiling is about done, but the far corners are still pretty rough and will get profiled more in another setup.
Finally a quick deburr with the tool bit that I used to face the piece (forgot to shoot that process).
I've left the whole body a bit oversize on purpose. I can cut it down if I want to later, but I was thinking that since this is a two port banjo, maybe I'd make it a bit oversize inside for increased flow. I would rather cut the inside bore first and leave a little extra beef for now.
I am not trying to follow the print exactly, but having the print handy keeps me from overcutting and it is real hard to "cut it bigger."
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
Forklift Safety Basket Attachment (A56857)
Forklift Safety...
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55315)
BOSS 990 Fuel...
84'' SKID STEER BUCKET (A56857)
84'' SKID STEER...
