Comparison Sa424
/ Sa424 #1
Rutman
Bostic, NC
Yanmar sa424
You guys that own a bush hog.
What size you running?
4 or 5 ft.
Wondering if it’ll run a 5 footer ok.
/ Sa424 #2
You could quite reasonably run either, but as is often the case the larger implement may require you to just go a little slower, take a little more time, if you're getting bogged down.
/ Sa424 #3
4 or 5 ft.
I run a 5' on mine. Handles it like a breeze, but I'm usually just cutting grass not brush so much. Field was about 18"-24" tall when I mowed the other day.
/ Sa424 #4
Yes it will handle a 5ft. I went with a heavier duty 4ft instead, so less bogging while I'm cutting trails with saplings and weeds/brush up to 8ft high. 5ft is fine for flat fields of weeds. Plus the smaller size makes it easier to navigate the woods
/ Sa424 #5
Not to hi-jack the thread, somewhat along the lines of the what the OP posted though. Have any of you pulled a 5' disk or 5' tiller with your SA? Would it handle either?
/ Sa424 #6
I think it would pull a 5' disk easily enough. A 5' tiller might be a bit much, depending on soil type and depth. If I ever get one for mine I'll probably get a 54" - just enough to cover the tire tracks
/ Sa424 #7
I run a 60" Yanmar/Woods tiller behind my SA424 no issues with it at all.
Issue with the disk would be maintaining traction and working depth versus soil type and trash levels. I only have disc experience with implements far too heavy to lift with the SA and thus I am uncertain how to translate my experience with disc narrows to implements of a scale suitable for the SA424
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
Used 20' Container (A62679)
Used 20' Container...
Power command Transfer Switch (A62679)
Power command...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
LOOK! (A63109)
LOOK! (A63109)
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
