Comparison Sa424
/ Sa424 #1
Rutman
Bostic, NC
Yanmar sa424
You guys that own a bush hog.
What size you running?
4 or 5 ft.
Wondering if it’ll run a 5 footer ok.
/ Sa424 #2
You could quite reasonably run either, but as is often the case the larger implement may require you to just go a little slower, take a little more time, if you're getting bogged down.
/ Sa424 #3
4 or 5 ft.
I run a 5' on mine. Handles it like a breeze, but I'm usually just cutting grass not brush so much. Field was about 18"-24" tall when I mowed the other day.
/ Sa424 #4
Yes it will handle a 5ft. I went with a heavier duty 4ft instead, so less bogging while I'm cutting trails with saplings and weeds/brush up to 8ft high. 5ft is fine for flat fields of weeds. Plus the smaller size makes it easier to navigate the woods
/ Sa424 #5
Not to hi-jack the thread, somewhat along the lines of the what the OP posted though. Have any of you pulled a 5' disk or 5' tiller with your SA? Would it handle either?
/ Sa424 #6
I think it would pull a 5' disk easily enough. A 5' tiller might be a bit much, depending on soil type and depth. If I ever get one for mine I'll probably get a 54" - just enough to cover the tire tracks
/ Sa424 #7
I run a 60" Yanmar/Woods tiller behind my SA424 no issues with it at all.
Issue with the disk would be maintaining traction and working depth versus soil type and trash levels. I only have disc experience with implements far too heavy to lift with the SA and thus I am uncertain how to translate my experience with disc narrows to implements of a scale suitable for the SA424
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
SUSPENSION PARTS OFR FORD F150 (A64276)
SUSPENSION PARTS...
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
Frontier RC2072 (A64126)
Frontier RC2072...
JOHN DEERE 6500 SELF PROPELLED SPRAYER (A64276)
JOHN DEERE 6500...
