S570 pump help
/ S570 pump help #1
sundown57
taunton ma
bobcat
i need to replace the injector pump on DOOSAN D24 I can not find any info on how to time it to put it back in. Any one know of a video or have info on it? thanks
/ S570 pump help #2
S570 is a Mitsubishi-Satoh compact tractor. Not sure what a D24 actually is.
/ S570 pump help #3
If u can post a pic of the inj pump, I can probably walk u thru it.. but I have to know what system I’m dealing with.
Or send a prvt msg.
/ S570 pump help #5
It looks like it’s a common rail inj pump..
The timing is set at the factory with different keys in the drive shaft of the pump..
U r gonna need a puller to pop the gear off tho..
The reason those pumps fail is: bad supply pumps..& dirty filters..& running the tank to empty..to where it sucks up the crud at the bottom of the tank..
MOST manufacturers will NOT warranty a pump without purchasing a new supply pump also..
Good luck
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
2023 Bobcat T86 (A64126)
2023 Bobcat T86...
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
2019 Ford Explorer AWD SUV (A61574)
2019 Ford Explorer...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
