S570 pump help
/ S570 pump help #1
sundown57
taunton ma
bobcat
i need to replace the injector pump on DOOSAN D24 I can not find any info on how to time it to put it back in. Any one know of a video or have info on it? thanks
/ S570 pump help #2
S570 is a Mitsubishi-Satoh compact tractor. Not sure what a D24 actually is.
/ S570 pump help #3
If u can post a pic of the inj pump, I can probably walk u thru it.. but I have to know what system I’m dealing with.
Or send a prvt msg.
/ S570 pump help #5
It looks like it’s a common rail inj pump..
The timing is set at the factory with different keys in the drive shaft of the pump..
U r gonna need a puller to pop the gear off tho..
The reason those pumps fail is: bad supply pumps..& dirty filters..& running the tank to empty..to where it sucks up the crud at the bottom of the tank..
MOST manufacturers will NOT warranty a pump without purchasing a new supply pump also..
Good luck
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
JOHN DEERE 1760 MAXEMERGE XP 12-ROW PLANTER (A64280)
JOHN DEERE 1760...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
3012SFL (A61567)
3012SFL (A61567)
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
