RX7320 problems @7 hrs on the meter
   / RX7320 problems @7 hrs on the meter #121
woolyAcres,
What size tractor are you using?
TPH,
I have been wanting to get my tires filled just haven't got around to it. If I was aware of this site when I bought it they would have been filled. Learned a lot reading different post.
   / RX7320 problems @7 hrs on the meter #122
@catfever we used the 7320 last year. For the 5+years prior we used an old Case 1490, 2wd. The case is higher hp but lighter than the kioti if we remove the loader from the kioti. In a pinch we've run that baler with the a NH TC45, only on the flat and pretty slowly but that baler doesn't need much hp.
Mugeye, I read on one of your other posts that you pull a chisel plow with your 7320. What size of a plow are you pulling with it and what kind of soil are ya in?
How heavy round bales are you making? 1500ish lbs?
   / RX7320 problems @7 hrs on the meter #126
1500 lbs bales . Loaded tires . 11 shank Chisel plow with harrows in hard *** clay . Pull it with more traction then my 830 case . But the 830 has more low end torque
Mugeye, I don't recall if I have ever asked you this, but have you ever ran a moldboard plow with your 7320? I'm considering getting a 3 bottom turnover plow. Pretty sure it would pull it easy enough. Had though about a 4 bottom, but then decided even if it would pull it the 3 bottom will be more maneuverable.
   / RX7320 problems @7 hrs on the meter #129
I pulled a 4 bottom with my 830 . But never tried the 7320 on it . I thing it would a 3 bottom no sweat
Ive got some pretty heavy clay here too. I've got a 3 bottom plow lined out that I think I will go pick up this weekend. Then it will just be a matter of figuring out what just the right amount of moisture is to work the soil. Oh, and waiting for it to thaw!
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
VERMEER PD10 PILE DRIVER (A52709)
VERMEER PD10 PILE...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
