RX7320 problems @7 hrs on the meter
   / RX7320 problems @7 hrs on the meter #121
woolyAcres,
What size tractor are you using?
TPH,
I have been wanting to get my tires filled just haven't got around to it. If I was aware of this site when I bought it they would have been filled. Learned a lot reading different post.
   / RX7320 problems @7 hrs on the meter #122
@catfever we used the 7320 last year. For the 5+years prior we used an old Case 1490, 2wd. The case is higher hp but lighter than the kioti if we remove the loader from the kioti. In a pinch we've run that baler with the a NH TC45, only on the flat and pretty slowly but that baler doesn't need much hp.
Mugeye, I read on one of your other posts that you pull a chisel plow with your 7320. What size of a plow are you pulling with it and what kind of soil are ya in?
How heavy round bales are you making? 1500ish lbs?
   / RX7320 problems @7 hrs on the meter #126
1500 lbs bales . Loaded tires . 11 shank Chisel plow with harrows in hard *** clay . Pull it with more traction then my 830 case . But the 830 has more low end torque
Mugeye, I don't recall if I have ever asked you this, but have you ever ran a moldboard plow with your 7320? I'm considering getting a 3 bottom turnover plow. Pretty sure it would pull it easy enough. Had though about a 4 bottom, but then decided even if it would pull it the 3 bottom will be more maneuverable.
   / RX7320 problems @7 hrs on the meter #129
I pulled a 4 bottom with my 830 . But never tried the 7320 on it . I thing it would a 3 bottom no sweat
Ive got some pretty heavy clay here too. I've got a 3 bottom plow lined out that I think I will go pick up this weekend. Then it will just be a matter of figuring out what just the right amount of moisture is to work the soil. Oh, and waiting for it to thaw!
2006 Hackney T/A Hazmat Truck (A56858)
2006 Hackney T/A...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
