RX7320 problems @7 hrs on the meter
   / RX7320 problems @7 hrs on the meter #61
The IH magnum series tractors have low level water sensor in them and I'm sure others do.
You can also get aftermarket systems such as this;
Davies Craig Low Coolant Level Alarm | JEGS
Also years ago when I was running a stock car we used a low pressure switch to alarm on a lose of pressure, it would be on till the engine warmed up a bit,
as I recalled it was about a 5 psi switch.
   / RX7320 problems @7 hrs on the meter #62
Sorry, like a woman, I'm back after I said I was done. Strangely, I found almost all of the coolant presence systems in Australia and most quite expensive. I got a tip from my mechanic who works on the old GM front wheel drive motor coaches. They use a Corvette coolant sensor system. A cheap little board you can buy on E-Bay and every component on there, I can test and replace dirt cheap. It works.
Coolant presence systems are quite RARE in the grand scheme of things and some only have them on the recovery tank. Basically a float switch. Murphy makes some very large float type apparatus for large engines.
   / RX7320 problems @7 hrs on the meter #63
OP, go back and carefully read Coyote Machines last two posts carefully, IE, Kioti may be tracking a “known problem” or an “emerging known problem” with that heaters compatibility with your block. He is giving you very good advice that could save you bigly... at least give you some piece of mind if you have a future related engine issue.
   / RX7320 problems @7 hrs on the meter #64
I spoke to my dealer today and he said they haven't had any issues like this. I also asked if there has been any service bulletin suggesting a bracket be used or block heater not be installed and he said 'no' but that he'd bring it up the next time he talks with the regional Kioti rep. I'll post back if/when I hear anything.
Of no help to Partyhound, but perhaps the dealer that sold him his has had this issue before due to incorrect procedure and/or tools at their shop?
   / RX7320 problems @7 hrs on the meter #65
As of right now the plan is to get the compression checked and go from there. Are you thinking that if the compression check comes back ok, there could still be other problems?
I had thought that the bearings could have taken a beating with the pistons no longer freely moving in their bores. Also, the head could have become slightly warped which would eventually present itself as a leaky head gasket, coolant loss over time, etc. I wouldn't expect there to be any damage to the valve train, but I'm a shadetree mechanic at best so I could be missing something. I guess at this point the best I can reasonably expect to get is a compression test done to determine if any cylinder wall damage has occured. As much as I would prefer to just get a different new tractor and start over, I really would not expect that they would give in and get me a new tractor over this. I think the best I can hope for is to do whatever tests there are to determine if any damage has been done.
It's your brand new tractor. I'm going to try to get you on the same page as me.
First, for background, I build a 150+ thousand dollar/year foreign auto business in the late seventies/early '80's. Started with a close friend trained at automotive school. We split after a few years and I bought him out. I also bought the building from the former owner, then sold the entire package in 1987, 15 days before the market crashed, and went on to other things, mostly because the chemicals and exhaust fumes were making me more and more ill.
We worked exclusively foreign autos, both brand new and used. We specialized in Volvos, and Saabs, two of Vermont's favorite vehicles. A fair amount of our traffic was Diesel Benzes, and a few Volvo diesels and some Volkswagon diesels too, reluctantly.
Anyway we almost always put in a remanufactured Benz diesel, we did not have time, and no extra space to do complete engine rebuilds, and the factory remans were cheaper and had the same factory warranty as a brand new engine, (if they even offered one then, I can't recall).
To boil it down I'm telling you, forget the compression check, approach the dealer for a new engine now. You may not get one, but your best chance is now- not later. Here's why: you bought a new tractor, with a new engine. You have a no longer new condition engine and someone is aware of the issue of these block heaters blowing out by now, I'm confident of this from dealing with Kioti for over ten years.
I spoke to an engineer I know today about this exact problem. He is a metallurgy expert with his own business. We talked about using Anerobic Locktite and sealing metal to metal without any other means of securing the bushing to the block. Then screwing in the actual heater into the bushing after the bushing mating process is properly completed and correctly torqued to manufacturer's specs. We agreed that even a slight error in sizing of either the B. heater's bushing or the freeze plug hole diameter would allow the B. heater to loosen during expansion/contraction cycles, and it would allow the weak link, the B. heater to become a projectile, because they are designed to work by a force fit, coupled with the red Locktite, which is meant to be permanent, NOT the removable blue color.
We discussed the way the freeze plugs are convex prior to install, then are hammered in the center to force them to dent to concave, which pressurizes the freeze plug and deforms it to concave, making for a 'press fit ' into the block's machined external edge. The freeze plugs from the factory seldom leak.
I don't know if you asked for a block heater for your new Kioti, or if your dealer installs one in each tractor as a preventative measure due to your climate locally? I would like us all to know this info please. Please provide same.
Kioti stands behind their product, as has been my experience over the past ten years. BUT you have to make a case to them through their dealer network, and ultimately through Kioti Corporate. It may take some time, but you will likely gain NO ground with a compression test. It will NOT show you what you seek, and it could hurt your ultimate outcome if it shows normal range numbers. I suspect it will. It would be hard to destroy a diesel by seizure with such low hours. I'm not saying it's impossible, but it's highly unlikely, especially since your failure was at mid-block and drained coolant down away from the top end. It's also why I believe your thinking about top end damage is wrong. This is exactly where the other OP's engine suffered excessive heat and caused the need for a complete rebuild or replacement.
Had the heater caused loss of oil, that's a different situation. But it's NOT your problem. If damage started to occur it would first happen to the top end- everything from the block to head interface and all parts, especially the weaker ones like valve collets and such. All engine parts can fail from over stressing them, whether it be by loss of oil or coolant. Your failure was due to rapid loss of coolant and it matches the situation the other thread OP had with his low hours on his engine WITH blow out of the block heater. In both your AND his engines the block heater blew out of the block due to either improper installation OR due to fitment failure due to a spec the does not allow the B. heater to stay intact to the block mating surface.
A number of B. heater failures, failing the same way on tractors recently in different parts of the country, speaks to me as a flaw in mating. Less likely is installation error, since most we've heard of are occurring with low hours, regardless of whether still covered by warranty or not. And numerous techs installing these incorrectly is possible but less likely, because unless a junior mechanic with little experience is doing the installs the top end techs take pride in their work, and the same failure is less likely to occur in different places and result in the basic same outcome- B. heater blow out,- result top end parts fail due to excessive heat, and trash the engine.
One other possibility could be in play, though less likely. Let's assume that the B.heaters which have 'scramed' are due to improper install to the extent that the cooling system trapped unpurged air somewhere in the system that at some random point built up excessive pressure and then that excess pressure blew out the weakest link - the poorly fitting B.heater causing the otherwise known chain of events of rapid loss of coolant. Diesels run cool compared to most internal combustion engines, so it is sometimes difficult to get air bubbles to float to the top of the radiator neck. Once an engine gets those bubbles to eventually rise they can block the passage of coolant and then excessive pressure can occur from trapped air, which often is not registered by the coolant gauge. Once the air bubble restrict coolant flow through it's passages, especially in the top end, pressure has to release from easiest release point; in this case via B.heater blow out. Most important when coolant stops flowing to the top end the metal temperature skyrockets and the metal has no way to extract the excess heat since only coolant liquid is what cools the head/top end, NOT excessively hot air.
I'm trying to get you to see the way to accomplish preventing this from happening to your brand new tractor.
Doing the compression test is like changing a tire when you need a battery, it just isn't going to tell you what you need to know. If your tractor was 4 years old with 1200hrs. on the clock, it might be able to give you cylinder ranges of numbers or show a weak cylinder. If I thought it would help you I'd say go ahead. For future reference: if a good outcome doesn't happen with your dealer/Kioti Corporate, you could do an oil analysis right now to see if any coolant got into your oil. This could easily become a fatal outcome since coolant is an enchant, NOT a lubricant like oil.
Furthermore this is and isn't your problem. It is because it happened to your new tractor. It more importantly isn't your problem because it happened right away, they knew exactly where you should look and pointed you there, AND they had on hand what it took to get you up and running for NOW.
One last time- for your best result act right now, ask the owner at the dealer to start the communication with your area's zone rep, and for the dealer to contact Kioti corporate, in addition let them know you plan to do so as well, immediately. Tell everyone you seek a brand new engine, if not a new tractor. And that you do NOT want another B.heater for any reason- even if it's a newer revised part! (ONLY release the original B. heater if required to do so by the zone rep, or Kioti Corp, and get it in writing that they required it to fulfil your warranty). While you wait for the answer to your new replacement engine/tractor, have your dealer install a new freeze plug so this cannot happen again to your existing engine!
While you're at it get your dealer to say if your tractor's controls include a shut down device for low coolant, or if it is able to go into a 'limp home mode' like on outboard motors, via the computer. It would be worth knowing for future reference for all Kioti fans...
If I can give more detail, don't hesitate to post again with questions or PM me, or both.
Try your best to keep your temper with all those you encounter in person, by phone or email.
Good luck, remember you won't get anything if you don't stand your ground. You deserve a new unit, not a patch. This is on Kioti. Don't let fear of a negative outcome stand in your way.
FWIW, you will be helping add to the Kioti Pak's overall knowledge which 'pays back' to all who take their time and knowledge and share it here. I've learned a ton from posting here over the last ten, and never stop learning from those with more knowledge than me. They exist?!:confused2::laughing:
Oh yeah, read the other thread(s) as far as they make sense. If we knew then what we do now that thread would have gone way better, but we could not get what we needed to help as we are trying to do for you..unfortunate outcome.
BTW, I plan to add a addendum to the other thread to clarify for anyone reading it, to link back to your thread for updated info...
CM
   / RX7320 problems @7 hrs on the meter #66
I’ll add my $.02:
1-I’d go ahead and pull an oil sample and send it to Blackstone. If any piston/ring/ cylinder material scuffed it might show in an analysis.
2-make sure dealer has a written statement that clearly states the tractor was suspect to overheating due to coolant loss and you noticed a power loss along with the RPMs unable to go above 2000.
The thing is no one knows how hot it got. Gauge will be useless without coolant passing over it. If that heater popped out at 1 hour and you ran it 6 more without coolant, the engine will have damage.
Personally, I’d push for a new machine.
   / RX7320 problems @7 hrs on the meter #67
I should add that running the water pump without coolant didn’t do that thing any good either.
   / RX7320 problems @7 hrs on the meter #68
I’ll add my $.02:
I agree with all the above, with one exception: oil analysis is a great way to track wear over time, meaning as a long term wear indicator of an engine's overall condition and as a predictor of when a rebuild may be needed. Your engine's situation is different because it is too new to have anything to compare it to it's last oil change, for instance. BUT, if coolant entered the oil or excessive metals show up in the first oil change, it could confirm the overheat/wear conditions you are looking to find. If so it would possibly indicate a near term failure on the horizon. Essentially engine will be toast, whether the B. heater pops again or not. Result run away from that engine/tractor. I don't know for sure if asking for a completely new tractor and having, possibly to settle for a new engine is the best option, or not. It's difficult to say what Kioti will decide, but I'd hope they do you right in your situation.
Regardless of anything else, lookup Blackstone Labs and or call them to find out the exact prep you need to do to get a sample and how much oil they need, whether you need to run the engine to temp or not before sampling etc. Do what they say, EXACTLY as they tell you to, and get enough sample oil to have at least 3 samples. One for them, one to keep, and a third in case Kioti wants an analysis for their own tests. Change the filter too, and mark the exact hours and date on the filter body. Store the filter with whatever oil is left in it for reference, in a ziplock baggie.
Most labs can do coolant analysis too, so that might be worthwhile to see if there are metals present that shouldn't be at such low hours.
Good call Ortimber!
   / RX7320 problems @7 hrs on the meter #69
The first thing I would want done if it was my tractor is drop the oil pan and rotate the crank checking the cylinder walls and piston skirts for scuffing, then pull the valve cover and check the overhead. The engine lost power because it was starting to seize up from lack of coolant. Usually caused by the piston rings or the pistons. Went it over heated everything started to expand and something got tight. If it got hot enough, which it probably did then there is a good chance the piston rings lost temper, and if the cylinders are scuffed it will start using oil once the rings wear down. Save your time on a compression test and drop the oil pan and check the bottom end first, then check the overhead.
   / RX7320 problems @7 hrs on the meter #70
Compression test is a waste of time. It will never identify incipient ring and bore scuffing
I would pull the injectors and use a borescope to inspect the cylinder walls and pull an oil sample to check for iron other wear metals. I assume Kioti uses plasma faced rings.
The dealer should also do a crankcase pressure test to check for excessive blow by, assuming Kioti has a documented procedure. Most Diesel engine manufacturers have such a procedure in the service manuals.
Is the block heater factory installed or does the dealer install it?
I don’t think my Kioti has one, so I suspect it is a dealer option........ If the dealer installed it, I would suspect an installation issue.
It’s also possible, though unlikely that a high temperature / pressure overheating situation, or even a frozen cooling system could cause the block heater to blow out.
   / RX7320 problems @7 hrs on the meter #71
I see possible problem here. If the dealer installed the block heater, it's unlikely that the manufacturer will stand behind any repairs. They will probably throw it back to the dealer who possibly did an improper install. If the block heater is a genuine Kite part, then they may have some liability.
   / RX7320 problems @7 hrs on the meter #72
It looks to be the same brand as mine from 2010, a Katz brand I believe to fit a Kioti. They aren't usually needed on Kite(s)!, unless in very cold winds! :)
To the OP be careful about 'pulling something like the oil pan yourself, you could void the very warranty you need to get you through, same with bore scoping after removing the injectors, both are great ideas; if you're going to do either procedure, have your dealer do it and show you the results as they occur in their shop.
Sorry I have been AWOL for a bit here fellas. Trying to keep calves alive in this weather has been rough. I appreciate all of your suggestions. I will get an oil sample sent off, that is a good plan. If anything in the oil sample suggests damage, it will give me more ammunition to get things set right.
Either way, anything being done with the tractor will have to wait till after this weather improves. I'm out, I gotta grab a few hours of shuteye!
   / RX7320 problems @7 hrs on the meter #74
I値l add my $.02:
1-I壇 go ahead and pull an oil sample and send it to Blackstone. If any piston/ring/ cylinder material scuffed it might show in an analysis.
Personally, I壇 push for a new machine.
x2 on this. an oil sample will tell you most everything you need to know in a situation like this, and would be great evidence to use moving forward.
   / RX7320 problems @7 hrs on the meter #75
I have never seen what the printed results of an oil analysis looks like. I do think that an engine with 7 hrs. on it is barely broken in and will normally have a lot of metal filings in the oil.
I was thinking the same thing. Still, it would also detect any coolant in the oil. Maybe there is a "normal" range of metal particulate suspended in the oil for an engine during break in, and if damage had occured perhaps it would be well outside of this normal range.
Well, up to this point the tractor had been running. It appears that even after it gelled up the first time they still did not properly treat the fuel and it gelled up again. Now its stopped in the driveway not running. So much for the reliability of a new tractor. I just called over to the guy that bought my old 1981 john deere...whaddya know, it's still up and running.
On a lighter note, it appears that my cow has been getting out of her pasture at night. It seems that she gave birth to a calf elk!
   / RX7320 problems @7 hrs on the meter #77
:thumbsup:
   / RX7320 problems @7 hrs on the meter #78
Undertstanding your Blackstone oil report on Vimeo this is a demo, from Blackstone oil analysis labs. Check out their site. We're looking for abnormal results on the engine oil, especially coolant.
   / RX7320 problems @7 hrs on the meter #79
Thanks for the video CM.
   / RX7320 problems @7 hrs on the meter #80
This is true to large degree, and something I had not considered. But I still think there is still a lot of value in a sample in this situation. Especially when looking at viscosity readings and film strength. Fluid degradation will be apparent in overheated oil, where regular, normally used oil, that is full of breakin materials will not be degraded very much from a viscosity, or film strength standpoint, especially at 7 hours of use. When oil overheats, larger molecules break down (refered to as thermal breakdown) which can be directly seen in the amount of additives still left in the oil. Barium, Calcium, Magnesium, as detergents can break down creating gases and acids.
You would need a reference sample of the type of oil used in your tractor to properly compare figures, especially when it comes to the TAN (total acid number), amount of additives, and viscosity.
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
2017 John Deere 5090GN (A53317)
2017 John Deere...
