RX7320 Owners - implement width?
/ RX7320 Owners - implement width? #1
BlueToy1
Central Missouri
Kubota MX6000
I'm looking to upgrade to an RX7320 with R1 ag tires set wide. The Kioti specs list minimum width at 77".
Can anyone tell me how wide of mower and box blade I'd need to cover the tire tracks? 84"?
Thanks
/ RX7320 Owners - implement width? #2
Thanks
The bucket on the FEL is 84", so I'd assume the tires are not wider than that even on the widest setting.
I didn't like the cab layout once I found one to sit in, so I got to start shopping all over. After I get a tractor, I'll be ordering a T & T.
Thanks
/ RX7320 Owners - implement width? #6
Thanks
Thanks, I was just wondering was all. Did you, or were you able to look at the larger frame sizes in the LS brand? I don't think that the cabs are all the same. Not trying to push LS, just wondering. :scratchchin: Pretty sure that LS has more gears with their tractor than Kioti does, and with the size tractor you are now looking at, 16 or more gears is nice. This from a guy with only 12 gears. :(
The ls5065 cab was good too. The Kioti seemed to be heavier built to me and the dealer went to a greater effort to complete the sale (much better deal).
Plus, my orange equipment will still match.
/ RX7320 Owners - implement width? #8
Thanks
I have industrial tires. R4's. My Woods BSM84 box blade sits proud of the tires by a few inches.
Thanks WoodChuckDad, I'll go with the 84"
/ RX7320 Owners - implement width? #10
I have the RX6010 pretty much the same tractor minus a few HP and I run a 84" with it, covers the wheel tracks by 6" on each side, in heavy CRP fields it is all the tractor wants though, the extra HP of the 7320 would be nice.
Thorholt, how long have you had it?
What are your biggest likes and dislikes?
Thanks
/ RX7320 Owners - implement width? #12
I have had it 3 years and no major complaints, I have about 400 hrs on it so far and really look forward to when I get to spend time in it, The only 2 things I have any gripes about would be that Mine has a rough cold start that has been that way since new, and the seat could use stiffer springs as it bottoms out a lot.
Glad to hear you've not had any problems. I'm looking forward to getting mine in about 10 days.
/ RX7320 Owners - implement width? #14
Here is a bit of unsolicited advice. No matter what someone says to you, get heavy duty implements..don't get anything that isn't rated at least to your machine. That tractor is strong and will pull lesser implements apart.
Thanks for your suggestion, I appreciate it.
/ RX7320 Owners - implement width? #16
Wish I had this advice when I bought mine. I told the salesman I wanted a disc and rear scrapper with the purchase. I ended up with the lightest duty stuff Land Pride offers. While they do work, at some point I will try to sell both and get heavier duty.
/ RX7320 Owners - implement width? #17
I just picked up a Land Pride landscape rake. This time I bought the heaviest one they make.
/ RX7320 Owners - implement width? #18
I went up one size and also got Heavy Duty Box Scraper and even a woods Batwing but that is not an issue but 15 foot is nice.
/ RX7320 Owners - implement width? #19
2018 FORD F-150 (A65643)
2018 FORD F-150...
FORD 2810 TRACTOR (A64277)
FORD 2810 TRACTOR...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
CATERPILLAR 304 EXCAVATOR (A65053)
CATERPILLAR 304...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
