Spreader Rustproof 3-Pt Fertilizer Spreader
/ Rustproof 3-Pt Fertilizer Spreader #1
fluttersmith
East Texas
Kubota M100GX, L3130, JD 6310, JD 3020, NH TZ24DA, JD 450E
Does anyone know of brands or models of 3-pt fertilizer spreaders that are not plagued by rust? This would require a stainless steel or poly hopper, stainless gate hardware, and stainless spinner, as a minimum. I have not been able to locate such a spreader on the web.
/ Rustproof 3-Pt Fertilizer Spreader #2
Vicon has pendulum spreaders that are the best in the business. Their expensive new but you'll be lucky if you'll ever wear it out.
/ Rustproof 3-Pt Fertilizer Spreader #3
I second Roberts vote for VICON spreaders,
I wish they still had a ground drive unit for sale to the public.
To buy a ground drive pendulum spreader unit these days you have
purchase a system from horsedrawn implement dealer.
/ Rustproof 3-Pt Fertilizer Spreader #4
Agreed, Vicon is the best--and I had one-- but you still need to wash, dry and spray any metal with oil immediately after use. I now have a metal cone spreader that I immediately wash and oil when done and after 8 years there is nothing other than superficial rust. I run a ton through it per year.
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
Cherry Wood Boards (A65640)
Cherry Wood Boards...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
Jumper Cables (A64127)
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
