Spreader Rustproof 3-Pt Fertilizer Spreader
/ Rustproof 3-Pt Fertilizer Spreader #1
fluttersmith
East Texas
Kubota M100GX, L3130, JD 6310, JD 3020, NH TZ24DA, JD 450E
Does anyone know of brands or models of 3-pt fertilizer spreaders that are not plagued by rust? This would require a stainless steel or poly hopper, stainless gate hardware, and stainless spinner, as a minimum. I have not been able to locate such a spreader on the web.
/ Rustproof 3-Pt Fertilizer Spreader #2
Vicon has pendulum spreaders that are the best in the business. Their expensive new but you'll be lucky if you'll ever wear it out.
/ Rustproof 3-Pt Fertilizer Spreader #3
I second Roberts vote for VICON spreaders,
I wish they still had a ground drive unit for sale to the public.
To buy a ground drive pendulum spreader unit these days you have
purchase a system from horsedrawn implement dealer.
/ Rustproof 3-Pt Fertilizer Spreader #4
Agreed, Vicon is the best--and I had one-- but you still need to wash, dry and spray any metal with oil immediately after use. I now have a metal cone spreader that I immediately wash and oil when done and after 8 years there is nothing other than superficial rust. I run a ton through it per year.
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
2018 TAKEUCHI TL8 SKID STEER (A59914)
2018 TAKEUCHI TL8...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
Case 1150G Dozer (A66285)
Case 1150G Dozer...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
