Rust protection comparison
/ Rust protection comparison #41
I sprayed FF on my FEL and it still had stuck snow.. I will re-spray; but, so far not impressed.
/ Rust protection comparison #42
We had good luck with Pam Cooking Spray.
Chris
/ Rust protection comparison #43
how about doing one with diesel? its a bit late...but it would be interesting for sure.
of what you got there, i m going with FF, just because its thickest
Add a few percent compressor oil into the diesel. It has corrosion inhibitors to combat the moist environment of a compressor crankcase.
larry
/ Rust protection comparison #44
I've always used the red or green rust check cans, and had good luck. I wonder if you can still buy it?
/ Rust protection comparison #45
larry
The diesel suggestion was based in the claim by a member that diesel has no rust preventing properties.
I mentioned it to see if it did (as has been my experience)
Interesting on the compressor oil however:thumbsup:
/ Rust protection comparison #47
I sprayed fluid film on my forks ...as you can see ,after a couple of weeks outside,its pretty rusty.
/ Rust protection comparison #48
Yes. As Mace said.
I just bought a spray can of Green to treat my sliding tonneau cover. Works great to keep it from freezing in the track. I got mine at NAPA, its available at crappy too.
There has been some discussion that Rust Check has caved to their applicators demands and forced retailers to remove the larger buckets of Red from the shelves to prevent DIYers. Ill have to try and confirm that next time im in NAPA
/ Rust protection comparison #49
I make same test with 15 products
Krown T40
RustCheck Red
RustCheck Green
DuraTech
Metropolitain Bio
Metropolitain Old
Formula 3000
Fluid Film
WD40
Boeshield T-9
ACF-50
KleenFlow PWD
Liquid Wrend Lubrifiant
ReleaseAll
SprayOn 711
Rust Check, Metropolitain Bio and Formula 3000 are thicker
I put stuff on steel bar 02-09-2014, spray salt water 5-6 times, wipe bottom (+- 1 inch), spray salt water 2 more times and wash with soft water. 03-01-2014 picture show results.
First: Liquid Wrench (I dont understand. It was not my first choice)
Second (ex-aequo): T40, Metro Bio, Formula 3000, WD-40 (Yes), T-9 and ACF-50
Next step, I will use high-pressure washer and salt water again.
/ Rust protection comparison #50
That's pretty cool. I would not have expected liquid wrench and wd-40 to do so well. Did you do any prep to the steel before you coated them? I notice that allot of the samples have rust around the fastener which could be the acids from your fingers when you mounted the samples.
Welcome to TBN by the way!
/ Rust protection comparison #51
I just sand the bar to clean previous rust. The black spot on Liquid Wrench came from first life of steel bar. The top of bar were not spray because my finger cover it.
I make this test to find the best rust proofing stuff. A stuff able to penetrate in small crack. Not a waxy thick stuff that keep moisture in crack.
/ Rust protection comparison #52
Glad I sprayed my truck with Crown! Thanks for the effort.
/ Rust protection comparison #53
Interesting.
But, if you do a real world, timed test, evaporation will change the results significantly.
When I have seen those done, WD40 is usually the first to go.
You can save yourself a lot of time, and just order some CorrosionX: Corrosion Technologies
/ Rust protection comparison #54
Ray66v: Thanks for info
Just order CorrosionX. I understand it is a aviation stuff like ACF-50. I order GLI SHIELD IT too. I also want to test LPS Hardcoat but only find it in gallon. Many industrial storage protector can be interresting to test but availiability for 1 spay can is complicated.
You are right about evaporation. Long terme test sould be interresting.
I made a first test with 7 stuffs on a more long terme (4 month). Probably my test is to aggresive (salt water) but most sample rust a lot. Form left to right: Rust Check Red / Krown T40 / Formula 3000 / Sprayon 103 / SprayOn 711 / WD-40 / M-55 / raw
Formula 300 was the only waxy stuff
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2018 INTERNATIONAL...
2021 John Deere 1775NT Planter (A63109)
2021 John Deere...
2022 John Deere Z930R Zero Turn (A63116)
2022 John Deere...
2024 John Deere 835M Gator (A63116)
2024 John Deere...
2015 New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
2015 New Holland...
