rust on rims!
/ rust on rims! #1
Old_Chipper
Had a flat on my John Deere, When they pulled the tire, rim had heavy rust inside. I had this rim blasted, primed (2 coats of the red stuff) then sprayed with 2 coats of the JD yellow. about a year ago. This is off a 85HP, big 36" rim. I don't use water in them. Why would it rust so soon? What do you use to coat the rim inside?
thanks
/ rust on rims! #2
You get moisture in the air from your compressor. I'd try painting with POR, it's worked for me in situations like this.
/ rust on rims! #3
Run the air through a water separator. Or fill with something else. Isn't that the new thing with cars. I worked for someone who filled mobile home tires with a propane bottle.
/ rust on rims! #5
Was the tank just a conversion to be a portable compressed air tank? That is pretty common.
Ken
I misunderstood. We used a 20lb. bottle of propane with no regulator. It let us fill a lot of tires where no electricity was available.
/ rust on rims! #6
thanks
assuming tubeless, then it was probably condensed moisture from the air / air compressor.
I like to paint rims with epoxy paint after cleaning them up and using a rust converting primer.
I'd think your clean/prime/2 coats of paint should be good. paint protects metal..
soundguy
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
Water Wagon (A64126)
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
2x4x8 Utility (A62613)
