Rust getting bad all over my Kubota
   / Rust getting bad all over my Kubota #11
There is something about the old steel that just didnt rust up like the new stuff does. Take a look at any old implement that has been setting out in the weeds for 40 years and they mostly are not pitted up with rust, most will just be lightly rusted and then seem to just stop at that point. Maybe it was the paint also. Lots of the old iron didnt have seam on the fender as they were one piece of pressed steel also so that limits the corrosion joint like we are seeing here.
   / Rust getting bad all over my Kubota #12
Anyone bring this up to a dealer or factory rep... Any warranty issues or experience with cosmetic or premature rust.
Lets be fair if you use your equipment in a road salt or sea side area rust would be expected to a degree but if you shed or barn your tractor that makes a difference and you should see many years before this type of rust is evident.
   / Rust getting bad all over my Kubota #13
ANyone here young enogh to remember the 74 chevy trucks that rusted....away?
   / Rust getting bad all over my Kubota #15
They still do that. They have more bling now, but they're still sh*tboxes.
JayC
   / Rust getting bad all over my Kubota #16
With the epoxies and polyurethanes available today, it is sad that so many tractor manufacturers choose to use inferior paint products. Most are using "direct to metal" alkyd enamel. When you read the fine print of such products, it says that primer should be used "for best results". Next time another flake of paint falls off your 30000 dollar tractor, look to see if it has primer on it. Chances are it does not.
Would good paint cost more? Definitely. Who wouldn't pay an extra 500 for paint that would last?
   / Rust getting bad all over my Kubota #18
Ok I admit Im a pretty big fan of Kubota tractors and I had L3400 then traded it in and got a L4400 back in 08. Well its been great I got about 650 something hours on it. Everything works to my expectations and power is great for what I due.
The thing that is starting to bother me is rust starthing show up all over the fenders. Anyplace where a panel is bolted to another panel is like a cancer that is just spreading up and down the seams.
I will have to add some photos. I just can see how in 4yrs all this rust would be starting to take over all my fenders. Yes the tractor sits outside but my Grandfather had 1960 something Alis Chalmers tractor and it didnt have the type of rust I got.
Not a Kubota but just so ya know. My 08, JD2320 looks worse than your Kubota and always keep undercover. My 88, JD650, I had for 20 years, did not look as bad as the 2320 we have now when I traded it. And yes it kinda upsets me.
   / Rust getting bad all over my Kubota #19
:)Back in the 60s when there were a few "shady" car dealers in Ky one had to be a little careful when buying a used car. Occassionally sawdust would find its way into transmissions and baling wire would be in different locations under the vehicle. Course back in the old days metal was thicker and better:). Some remember the good ole days different than I do.:) I remember tires wearing out in 5000 miles and batteries that maybe lasted 2 years. Maybe even drive shafts that would sometimes find them selves on the hwy instead of between the engine and rear end. Radios that maybe picked up the local station sometimes.
Anyway, in Ky the biggest scam was used car dealers bringing cars down from Ohio and heaven forbid you got a car from Michigan.:) The buyer always knew it within a few months when parts started falling off of the car where the rust would eat thru and there was never a doubt where fenders were attached, just follow the rust line.
I know, the ole days were a lot better and that's why we still have all those old cars, trucks and tractors still available to buy today. Great ole stuff!!!:D
   / Rust getting bad all over my Kubota #20
Kubota uses primer, I've got rock chips from bucket spill onto my hood, primer is plain and clear.
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
2018 HINO SA (A58214)
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
208320 (A58375)
208320 (A58375)
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
