Runs wide open
/ Runs wide open #1
Dr M
Hello All,
I started my Yanmar last night.........it started full blast and the only way i could shut it down was to pull the compression down....
Any ideas????
I was affraid it was going to blow>>>>>
Thank you.
Dave
/ Runs wide open
I pulled off the inspection plate, but the only thing I can see is the linkage and a spring that goes toward the front of the engine. Could something have come unhooked???
Is there a way to check the connection or test it???
Thanks again.
Dave
/ Runs wide open #3
I don't necessariliy know what is wrong, but perhaps you could post the tractor model and perhaps post a few photos.
/ Runs wide open
Opps, sorry.
It's a 1500D, not 4 wheel drive.
2 cyl, i think 17hp.
Ran great up till last night. It started and wound up like an electric motor...
Dave
/ Runs wide open #5
This response is pretty elementary since I know little about such things, but have you disconnected the linkage to the injection pump to see if that helps?
Also, did you have it idled down when you last killed it? I would check all of the linkages that contribute to fuel flow. Check the injection pump arm and see if it is in the idle position. Just get ready to quickly shut down if it starts to rpm up.
Wish I could help more, good luck.
/ Runs wide open
Thank you all.
I took off the inspection plate and the spring to the linkage was hung up on the slide mounted to the inside of the block. I oiled it up and cleaned it the best I could, changed the oil and gave it a try. It ran rough for a little, but did idle.........I shut it down, started it again and it seems to be just fine. Thank you guys, you're a big help.
Dave
20ft Shipping Container (A61166)
20ft Shipping...
John Deere 6125R (A60462)
John Deere 6125R...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
PALLET OF (3) BURNER GAS COOKER (A62131)
PALLET OF (3)...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
