Tires Running tractor tires on a zero turn
   / Running tractor tires on a zero turn #31
I just put WT300 tires on my ZD326P this spring and really like them so far. Much better traction and they don’t seem to scuff the turf as bad as the original tires that came on it. If been running ZD machines since 2002 so perhaps I operate the machine better now than when I got my first one. I’m glad I upgraded
Too bad my machine doesn't look as clean as yours! Way too dusty here...
   / Running tractor tires on a zero turn #32
As far as mounting they weren’t that bad but we couldn’t get them to air up. Had to go to a tire shop so they used those big volume tanks to seat the bead. My advice is take them to a tire shop
Yours can be clean too, soap and water is all it takes. Lol
   / Running tractor tires on a zero turn #33
Put a ratchet tie down around the circumference of the tire, tighten it a little, then seat the bead with air. Take the tie down off before fully inflating.
Do you have a side view of mower with new tires?
   / Running tractor tires on a zero turn #36
How do the tractor tires work for you? I’m considering putting some on my grasshopper for $120 each. The other option is chevron tires like my Dixie chopper.
   / Running tractor tires on a zero turn #37
The WT300 tires are 10/10 for me. I wish I put them on years ago. R3 turf tires are useless to me.
   / Running tractor tires on a zero turn #38
Tried that John, didn't work for me.
I used a liberal amount of dish soap on both the tire and rim. I also kept the tire vertical to catch the rim easier. Sometimes you just need 3 hands. The first tire caught perfectly on the first try. Second one I had to get a helper as I don’t have self locking inflator.
   / Running tractor tires on a zero turn #39
Do the sharp edges of the tractor tires cause any turf damage?
   / Running tractor tires on a zero turn #40
It's all in the operators hands.
I tear up grass less with the WT300's because they don't slide. On slopes the R3 Turfs slide no matter what because they have no traction. I have no tear up on slopes with the WT300's because I can now control it. If you control it like toggle switches (i.e. full forward to full reverse) you can tear it up good.
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
UNUSED FUTURE 32"...
2007 Ford Focus Hatchback (A54815)
2007 Ford Focus...
ARBOR PRESS (A57192)
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
