Tires Running tractor tires on a zero turn
   / Running tractor tires on a zero turn #21
The bar tires look good but I'm thinking they will tear out the grass in turns more than the R4 because of the sharp corners on the side of the treads. On wet grass or slightly muddy areas the turf tires are just slicks and provide zero traction in my experience. I think the turf tires tear up the grass more because they have less traction and more slip.
   / Running tractor tires on a zero turn #22
My neighbor has a grasshopper. It gets good traction. But, it's hard on the lawn.
You don't see those tires on golf course mowers for a reason.
Can't argue with that! Great point!
   / Running tractor tires on a zero turn #24
Here's an update for an older thread.
I just put on a set of WT300 turf bar tires and the difference in control is day and night. I'm a convert!
Here's a link to my blog post about them with photos.
Quest for a better Zero Turn Kubota ZD326-6P Modifications Divergent Stuff
   / Running tractor tires on a zero turn #25
Probably the best solution to your dilemma is a tire design that appears to be no longer available.
When I bought my B1750HST, in 1993, the rear tire options were turf, AG, industrial (R4), and "bar" (not AG). I choose the "bar" rear tires, which gear correctly with turf tires on the front. These tires have a zig zag bar pattern in the center of the tire with bars on either side. The tread is less aggressive that AG tires but more aggressive than turf tires. They are wider than AG or R-4 tires and even wider than turf tires. Tires with similar tread pattern were once common on off road only Jeep and other FWD vehicles. Sorry, no photos.
I have not seen this design offered on new CUTS/SCUTS for 15+ years, and no longer see them on off road Jeep type vehicles. They are not hard on the turf (not as forgiving as turfs but much better than R1s or even R4s), provide good side hill traction and are much better than either R1 or R4 tires in snow, indeed, even better than turfs. They also ride at least as well as turfs.
I would have specified these tires on my new B3350, delivered about 2 weeks ago, if they had been available but they were not. Rather, I was torn between turfs and R-4s, finally deciding on R-4s.
I will post an image of these tires if I can find one online.
SDT
   / Running tractor tires on a zero turn #26
SDT
Here's a representative photo.
KUBOTA B175HSD For Sale In Fredericksburg, Pennsylvania | TractorHouse.com
SDT
   / Running tractor tires on a zero turn #27
SDT
Probably the closest tire that is currently available (in terms of traction) would be the Carlsile All Trail or All Trail II. I have seen those on a few B series tractors and they (or something very similar) come on the Deere X series tractors: All Trail - All Trail II Tire
They also make a HD Field Trax that is similar: HD Field Trax Tire
Aaron Z
   / Running tractor tires on a zero turn #28
Here's the Carlisle WT300 profile from their website. Rounded corners make it a little less aggressive on the turns.
   / Running tractor tires on a zero turn #29
I just put WT300 tires on my ZD326P this spring and really like them so far. Much better traction and they don’t seem to scuff the turf as bad as the original tires that came on it. If been running ZD machines since 2002 so perhaps I operate the machine better now than when I got my first one. I’m glad I upgraded
Looks great!! I may need to get a set! Were they hard to mount like mentioned in blog post above?
2006 International 4300 2,000 Gallon Fuel Truck (A55852)
2006 International...
2012 Ford Fusion Sedan (A55853)
2012 Ford Fusion...
(8) 8 LUG 16" WHEELS (A57192)
(8) 8 LUG 16"...
2020 DRAGON ESP...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2013 TAKEUCHI TL10 SKID STEER (A52707)
2013 TAKEUCHI TL10...
