Tires Running tractor tires on a zero turn
   / Running tractor tires on a zero turn #11
I would think the tires pictured would make for a rough ride.
Tires with some side wall flex (similar to an ATV tire) would ride much better IMO.
   / Running tractor tires on a zero turn #12
I have R4s (I think...) on my BX. They can be pretty rough on my native grass "lawn" (not really a suburban lawn). I would never put them on a dedicated mower. They really tend to chew up the ground if I'm not careful. Which tends to be about once per seat session. They definitely look "cooler" than turf tires, but I don't see the benefit on a zero turn. Zero turns, by design, are made for very tight turns. All of the tires you are looking at are not. I can almost guarantee you won't like the combination.
   / Running tractor tires on a zero turn #13
Grasshopper mowers come with these: http://fixmytoys.net/images/stens/2_160-675.jpg
Gotta be a reason why. I find my turf tires spin too easily.
I had tires VERY similar to these on a 2wd mower, before I got my BX, to handle my hilly terrain. They worked wonders. (Mine were Carlisle.)
If you use your power to spin them, they will tear up your grass for sure... however if you don't get aggressive with them you won't have much/any damage because they grip really well and don't slip like turfs.
   / Running tractor tires on a zero turn #14
I wouldn't go with an R4 since it's stiffer and won't really have a traction benefit, so I don't see the point of it on a z-turn. R4 is mainly for handling heavy loads (ie, front loader or backhoe) and puncture resistance typical of construction use.
The one picture the OP posted of the ZD in the garage is mine. My ZD came with turfs but the turfs had poor traction in wet grass and the turfs would load-up with mud on very wet grasslands. My dealer suggested R4's, made all the difference in traction, I've yet to get stuck with the R4s.
After seven years of mowing four acres of wet grass, sometimes in standing water, sometime very dry ground, the R4's do not tear up the grass any more than the turfs did.
   / Running tractor tires on a zero turn #15
What is the reason or goal? I wouldn't go with an R4 since it's stiffer and won't really have a traction benefit, so I don't see the point of it on a z-turn. R4 is mainly for handling heavy loads (ie, front loader or backhoe) and puncture resistance typical of construction use.
I agree. If you drive 2 identical tractors, one with turfs, the other with r4 tires, you will feel how much stiffer the r4's are to live with. Also, r4's will not keep you from sliding sideways when slick.
   / Running tractor tires on a zero turn #16
What size tires did you use?
Thank you for response. There's two pics with ZDs in garage. Yours with the RTV or the other one?
   / Running tractor tires on a zero turn #18
   / Running tractor tires on a zero turn #19
I run bar tires on my zero turn, I have some hills and embankments, so added traction was necessary. On the lawn they tend to tear up grass if I zero turn, so a have to turn, back up and turn again. Luckily I don't have much "lawn" I managed to puncture the original tires on the sidewalls, local places wouldn't patch them, because, and I quote "You can't patch sidewalls because they will blow out at high speed" It's a lawnmower for crying out loud! Faced with having to buy new tires, I went with the bar type.
   / Running tractor tires on a zero turn #20
"Turn, backup, turn again".....
Commonly referred to as a K-turn or a 3-point turn.
And yes, that's a must on a ZTR even if you have turfs. Because even turfs will tear the sod if you try a "zero" turn.
Not patching a sidewall???? Get a $10 patch kit that has the tools, tube of cement, and the black licorice looking plugs.
Would I plug a sidewall in my car/truck....no. but have patched many many sidewalls in lawnmower and tractor tires over the years without. Single failure.
We Don't Dial 911 Wall Art (A55853)
We Don't Dial 911...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2012 Ford F-250 Pickup Truck (A55852)
2012 Ford F-250...
33ft Dovetail Flatbed Trailer (A55315)
33ft Dovetail...
UNUSED FUTURE SGB20 20" HYD STUMP GRAB BUCKET (A57193)
UNUSED FUTURE...
2017 Ford Transit 150 Cargo Van (A55852)
2017 Ford Transit...
