RoyJackson
Rest in Peace
- Joined
- Nov 17, 2001
- Messages
- 24,646
- Location
- Bethel, Vermont
- Tractor
- John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I always like these kinds of threads. It gives us some insight as to what can/should be used as counter weight to TPH attachments w/o Fel.
Each tractor should include this info. maybe a graph of some sort. Go right down the list, a RC you should have x amount of suit case weights on the front, a rototiller should have xxlbs and so on.
The Deere manuals do provide such information. However, this is based upon "implement codes" which, I assume, are Deere implements.
A little bit of research on the Deere site would get you the implement code and weight of a given implement (72" rotary cutter, for example) which corresponds to the front weight required (in the Deere tractor operators manual).
Obviously, Deere couldn't provide information for other manufacturers' implements since they have no control over them.
As far as other tractor manufacturers, I've no idea if they provide equivalent information, but it is worth a look in the operators manuals.
