Running 3000 series without side panels
   / Running 3000 series without side panels #11
My 3186 runs kind of hot too. I think it's kind of inherent with the design with the muffler up front. I try to keep the entire engine area clean, but it still seems pretty hot after a half hour.
Ok... it sounds like it is the nature of the beast.
I hose off complete tractor when done mowing, so every thing is squeaky clean.
That and good oil is I guess all you can do.
I may install an oil cooler.
   / Running 3000 series without side panels #13
Do away with that hosing off tractor!! Those units are not like a car rhat can sit outside in the weather or go thru a car wash with impunity. You will soon have various electrical probs from rust/corrosion, possibly also various bearing failures. A good blow-off with cmpressed air is much better. If needed, a judicious wipe down with a rag and bucket followed by a quick drying in the sun can work.
Worst of the washing options are the power washers - they will blast water into any number of no-no areas...
   / Running 3000 series without side panels #14
thats the truth, i found out the hard way on that one. i use the leaf blower to clean it off after cutting and wash it about once a month. i would also invest in a waterproof cover if yours isnt inside when your not using it.
   / Running 3000 series without side panels #15
With our last 2 CC's 582, 1440 we took the side panels off when it got hot. But that was then and this is now...the geniuses at MTD want to control the horizontal and the vertical.
Sure I'd remove the side panels if I were you.
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
SUV (A59231)
SUV (A59231)
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
