Rubber Pusher Plate
/ Rubber Pusher Plate #1
McCaskey
East Aurora, NY
I used some old skidsteer track to make a rubber pusher plate.
Adding 4 wings on each side.
Track was cut with a reciprocating saw with a 12 carbide blade, Outside, lots of smoke.
PXL_20201217_213709556.jpg PXL_20201217_213659138.jpg PXL_20201217_213715136.jpg
PXL_20201214_165425130.jpg PXL_20201214_200357358.jpg PXL_20201217_172705894.jpg
/ Rubber Pusher Plate #2
That's cool but what do you push? Cars? Cattle? Chickens? :confused3:
/ Rubber Pusher Plate #3
I agree; push what?
I mean, it's a nice job and something that you obviously need to do 'more than once' or else you wouldn't have gone to the effort to build it. :scratchchin:
/ Rubber Pusher Plate #4
@McCaskey that is awesome. I made a smaller one long ago but not as nice as yours. Mine slipped onto the forks of a wheel loader or forklift. And good idea using the track steer track
Definitely a top notch job
/ Rubber Pusher Plate #5
When building box stalls I needed to cut /trim floor matts.
Tried all kinds of saws, friction blades oil etc.
They would however create a smoke screen from burnt rubber.
Finally came up with a plan.
I would flop the floor matt over a 4 x 4 and using a new box blade c/w a straight edge make a cut (deep slit)
Being over the 4 x 4 a hump was formed allowing the slit to spread open and that reduced friction.
Usually 2-3 box blade passes and the 3/4 " matt was neatly cut where I wanted.
Also discovered that dish detergent sprayed in the cut zone acted like a lubricant while oils did not help.
HYSTER H80XM STRAIGHT MAST FORKLIFT (A64279)
HYSTER H80XM...
208735 (A60430)
208735 (A60430)
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
2012 International Prostar (A63118)
2012 International...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
