Rubber Pusher Plate
/ Rubber Pusher Plate #1
McCaskey
East Aurora, NY
I used some old skidsteer track to make a rubber pusher plate.
Adding 4 wings on each side.
Track was cut with a reciprocating saw with a 12 carbide blade, Outside, lots of smoke.
PXL_20201217_213709556.jpg PXL_20201217_213659138.jpg PXL_20201217_213715136.jpg
PXL_20201214_165425130.jpg PXL_20201214_200357358.jpg PXL_20201217_172705894.jpg
/ Rubber Pusher Plate #2
That's cool but what do you push? Cars? Cattle? Chickens? :confused3:
/ Rubber Pusher Plate #3
I agree; push what?
I mean, it's a nice job and something that you obviously need to do 'more than once' or else you wouldn't have gone to the effort to build it. :scratchchin:
/ Rubber Pusher Plate #4
@McCaskey that is awesome. I made a smaller one long ago but not as nice as yours. Mine slipped onto the forks of a wheel loader or forklift. And good idea using the track steer track
Definitely a top notch job
/ Rubber Pusher Plate #5
When building box stalls I needed to cut /trim floor matts.
Tried all kinds of saws, friction blades oil etc.
They would however create a smoke screen from burnt rubber.
Finally came up with a plan.
I would flop the floor matt over a 4 x 4 and using a new box blade c/w a straight edge make a cut (deep slit)
Being over the 4 x 4 a hump was formed allowing the slit to spread open and that reduced friction.
Usually 2-3 box blade passes and the 3/4 " matt was neatly cut where I wanted.
Also discovered that dish detergent sprayed in the cut zone acted like a lubricant while oils did not help.
2005 Suzuki King Quad 700 Fourwheeler (A61166)
2005 Suzuki King...
2004 Ford E-450 Jayco Escapade 28G Class C Motorhome (A61569)
2004 Ford E-450...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
