RTV500 Tail light
/ RTV500 Tail light #1
General Lee
Veteran Member
Mid-Atlantic
Kubota L4400, B2401
Anyone know where I can a whole tail light assembly besides a special order from the dealer? Hadn't had much luck poking around online.
/ RTV500 Tail light #2
Let me guess, you drove forward with the box up in dumping position? I have done that a time or two and the only place I found to get replacement lenses is the dealer. There are some that are similar they sell for trailers but I don't think they're the same. New
Aaron Z
/ RTV500 Tail light
LOL, You are correct. The bed was actually down with a load of wood in it. Drove forward but I forgot to latch the bed. The counter weight of the wood tilted the bed open and ....Crunch. I need the whole assembly, not just the lens.
/ RTV500 Tail light #4
I have broken two lenses dumping chicken manure from ours. I need to setup a limit cable to stop it before it hits the tire.
Aaron Z
/ RTV500 Tail light #5
A barrel of water in the back will have the same result. Busted mine last fall and couldn't find anything online either.
/ RTV500 Tail light #6
Must be a design fault if it hits the tires (or anything else) when dumping. My 900 lights have never broke and I have driven forward while in full dump many times. I have also backed into brush piles before dumping without an issue.
I think if I had one that hit and had broken the tail light once, I would relocate it to a position where it was protected. Also, a tail light is a tail light, just go to an auto parts store and get a new assembly for about $10-20 depending on what type you want. LED lights are going to be higher priced.
There should be a location that you can install a tail light that wont be in the way of dumping, be protected from limbs when dumping and still be visible. Building an armor plating around it might also be an option.
/ RTV500 Tail light #7
I agree that it is a design flaw. The wheel hits the fender and drags the fender under if you try to drive forward with the bed dumped.
Aaron Z
/ RTV500 Tail light #10
/ RTV500 Tail light
Those may work aczlan. I smashed the whole dang thing. Nothing is salvageable from it so just a surface mount may be the ticket.
/ RTV500 Tail light #12
If you have the roof on it, you could also get a pair of grommet mount lights to throw up there.
Aaron Z
/ RTV500 Tail light
I do have a roof. I don't really "need" the tail lights, its just I like to take care of my stuff and it kinda bugs me to have a busted light lol.
1989 FRUEHAUF TRAILER OPERATION FUEL TRAILER (A60736)
1989 FRUEHAUF...
2017 MACK CXU (PINNACLE) (A60736)
2017 MACK CXU...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A61567)
Challenger MT275B...
Komatsu PC200 Excavator (A60352)
Komatsu PC200...
Caterpillar TL1055D (A62177)
Caterpillar...
2009 Ford F-150 Ext. Cab Pickup Truck (A60352)
2009 Ford F-150...
