RTV1100 solutions?
/ RTV1100 solutions? #1
KubotaToy
SE Tennessee
Kubota LX331HSDC (hers) and L45 (mine), RTV1100 (hers)
It seems every time I load my bed up (which is almost daily due to cleaning the horse stalls and barn out), I am always getting dirt, hay, leaves and sticks falling between the cab and the bed on top of the motor. At the end of the day, I try to remember to go to the shop to blow the area under the bed out but that does not always happen and the next time I use it I smell the manure or hay getting hot. I am sure someone out there has the same problem and has a good solution. Attached is a picture of what I have done until I can find a permanent fix. I took some leftover plastic skirting from my race car and screwed it to the bed. It is not pretty but works.
/ RTV1100 solutions? #2
Orange aftermarket has a bulkhead bed extension but for $230. I think what you have looks great !
Those look nice, I wonder if they would work with the rear window guard, that is what keeps me from making a wood sideboards to give me a little more capacity. My give them a call.
/ RTV1100 solutions? #4
Is yours an RTV-X1100? If so, Kubota recently released a recall notice which installs a cover over the engine. I received the letter from Kubota and my dealer called me about a week ago to let me know he has the kits and to schedule an appointment.
/ RTV1100 solutions? #5
I had side boards and headache rack built to keep it in the bed. Zip tied cardboard sheets inside when hauling mulch.
/ RTV1100 solutions? #6
I
I am actually looking for the same solution I have ready to install a pre cut by me 8" x 57" rubber mat that I hope will lay over the bed to block crap from falling thru. I mounted to it 3 metal strips that I bent to help this form the shape I want. It should be about 3 inches higher then bed and just lay nicely over it. May not be a 100% solution but as long as it stays in place I should b able to keep the rtv clean and free of rain snow and other debre? I'll send pictures when it's done it us snowing now so I will need to clean n dry unit before attempting to do this install
/ RTV1100 solutions? #7
On my X900, and now my X1100C, I built a bulkhead and side extensions that work really well. If I hauled a lot of loose materials frequently I would add a firm rubber flap to the top of the bulkhead extension that seals off the gap between the bottom of the rear window and the bulkhead.
/ RTV1100 solutions? #8
I kept it simple, some heavy fabric ( black felt from fabric store) attached to my rear window screen. As bed goes up it moves out of way . When bed closed it us hehind , but with quick pull of corner it us back on inside of bed so hay or gravel etc won't get between window wall and bed wall.
/ RTV1100 solutions? #9
This was my solution. Square tubing with some scrap plastic wood (like trex) attached. Solved my manure hauling issues.
/ RTV1100 solutions? #10
This week
I added these cedar sides with hardwood stakes, for looks and to keep grandkids in. :)
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
2008 Ford F-350 9ft. Stake body Flatbed Truck (A61573)
2008 Ford F-350...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
29 x 9.0 x 15 Tires with 5 Lug Wheels (A61573)
29 x 9.0 x 15...
