RTV1100 solutions?
/ RTV1100 solutions? #1
KubotaToy
Gold Member
SE Tennessee
Kubota LX331HSDC (hers) and L45 (mine), RTV1100 (hers)
It seems every time I load my bed up (which is almost daily due to cleaning the horse stalls and barn out), I am always getting dirt, hay, leaves and sticks falling between the cab and the bed on top of the motor. At the end of the day, I try to remember to go to the shop to blow the area under the bed out but that does not always happen and the next time I use it I smell the manure or hay getting hot. I am sure someone out there has the same problem and has a good solution. Attached is a picture of what I have done until I can find a permanent fix. I took some leftover plastic skirting from my race car and screwed it to the bed. It is not pretty but works.
/ RTV1100 solutions? #2
Orange aftermarket has a bulkhead bed extension but for $230. I think what you have looks great !
Those look nice, I wonder if they would work with the rear window guard, that is what keeps me from making a wood sideboards to give me a little more capacity. My give them a call.
/ RTV1100 solutions? #4
Is yours an RTV-X1100? If so, Kubota recently released a recall notice which installs a cover over the engine. I received the letter from Kubota and my dealer called me about a week ago to let me know he has the kits and to schedule an appointment.
/ RTV1100 solutions? #5
I had side boards and headache rack built to keep it in the bed. Zip tied cardboard sheets inside when hauling mulch.
/ RTV1100 solutions? #6
I
I am actually looking for the same solution I have ready to install a pre cut by me 8" x 57" rubber mat that I hope will lay over the bed to block crap from falling thru. I mounted to it 3 metal strips that I bent to help this form the shape I want. It should be about 3 inches higher then bed and just lay nicely over it. May not be a 100% solution but as long as it stays in place I should b able to keep the rtv clean and free of rain snow and other debre? I'll send pictures when it's done it us snowing now so I will need to clean n dry unit before attempting to do this install
/ RTV1100 solutions? #7
On my X900, and now my X1100C, I built a bulkhead and side extensions that work really well. If I hauled a lot of loose materials frequently I would add a firm rubber flap to the top of the bulkhead extension that seals off the gap between the bottom of the rear window and the bulkhead.
/ RTV1100 solutions? #8
I kept it simple, some heavy fabric ( black felt from fabric store) attached to my rear window screen. As bed goes up it moves out of way . When bed closed it us hehind , but with quick pull of corner it us back on inside of bed so hay or gravel etc won't get between window wall and bed wall.
/ RTV1100 solutions? #9
This was my solution. Square tubing with some scrap plastic wood (like trex) attached. Solved my manure hauling issues.
/ RTV1100 solutions? #10
This week
I added these cedar sides with hardwood stakes, for looks and to keep grandkids in. :)
2012 CHEVROLET IMPALA CAR (A66091)
2012 CHEVROLET...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
(4) ForeRunner 12-16.5 N.H.S. Tires (A64912)
(4) ForeRunner...
2016 Nissan Frontier Crew Cab Pickup Truck (A66736)
2016 Nissan...
CAT 930 60" Forks (A68134)
CAT 930 60" Forks...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
