RSK 1504
/ RSK 1504 #12
Yes...shear bolt intact and the PTO clutch was not slipping (cold to touch). Everything from the pto to the top gear box, the side shaft to the final gear box was turning...except the actual cultivator blades. And they would turn when I lifted the implement...thus I believe the lower sprocket must be worn to the point where it won't take any load.
/ RSK 1504 #13
I really don't know what I am talking about so take this with a grain of salt. I wouldn't be surprised to find your tine shaft has a spline that splines onto the lower sprocket shaft. Wouldn't doubt you find that spline bad. May be a different connection altogether but I'm just purely speculating that is where you will find your problem.
/ RSK 1504 #14
Son and I were up this weekend and got into the machinery a little. Found a "machine key" that broke. It sits in a slot between the tiller shaft and the gear that turns it. Sooooo, if I can get a new key made, I think we're back in business!
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2014 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCNCPEH0EZ393232 (A61165)
2014 Chevrolet...
Toro Sand Pro (A56859)
20704 (A55853)
20704 (A55853)
1991 FORD F-800 BED TRUCK (A60736)
1991 FORD F-800...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
