Oil & Fuel RPMs at Diesel Start-up
   / RPMs at Diesel Start-up #21
</font><font color="blue" class="small">(
It must be when the glow plugs are turned on that some amount of fuel is allowed into the combustion chamber or something to allow the engine RPM to be higher than the throttle setting.
Randy )</font>
Not on an L3000. Electricity has nothing to do with it; it has a purely mechanical injection pump. It's nothing but the governor doing its job.
Thanks for all the responses!
It appears that the majority of you guys are doing the initial start-up at idle/low rpms which is probably what I'll do.
Manual states to heat glow plugs for 5-7 seconds, and as for variant temperature warm up times:
.......32 degrees F and up ------ 5-10 minutes.
......15-32 degrees ------------- 10-20 minutes.
....... -5-15 degrees -------------20-30 minutes.
...... less than minus 5 degrees --30 or more minutes.
Here in my part of N.C., 5-10 minute warmup is all I'll ever need to worry about.
   / RPMs at Diesel Start-up #23
I use 1200-1400 for startups and let her run there for a few mintues.
   / RPMs at Diesel Start-up #24
Don't know why people keep mentioning about it being bad to let diesels idle for long periods. In Vermont, bus drivers would leave their buses running all night long when it got down to about -20 F at night.
Of course, in the far north, they shut them down but have to have them plugged in to keep the engines warm in places where it can get to -40 and below. It's that or leave them idling.
Ralph
   / RPMs at Diesel Start-up #25
I have a 100 kW, 166 HP Perkins generator. When the automatic transfer switch transfers to generator power, the engine starts and goes straight to full speed. When the transfer switch returns to the Power Company, the engine just shuts off. I don’t know how smaller units work.
   / RPMs at Diesel Start-up #26
That's about the only way to run a demand system... you gotta have the power -now- and you may be starting under load... Now.. presumably, that generator is not meant but for intermittant use.. whereas a tractor is made for frequent use. My guess is if you started a tractor like that all the time, full throttle, with all hyds and pto load to click in at the moment of starting, I'd guess the engine would not last as long, vs the genny hat might have to do that? a couple times a month? max? It's a trade off.. instant power at the cost of some minscule percentage of engine life..
Soundguy
   / RPMs at Diesel Start-up #27
I've herd of some units that deliver max fuel at the injector pump reguardless of the throttle setting, based on the gov and fuel injector pump design.. after starting, then throttle setting is referenced.. etc. Also.. some pumps have an excess fuel knob to help with starting in extreme cold..
Soundguy
</font><font color="blue" class="small">( It must be when the glow plugs are turned on that some amount of fuel is allowed into the combustion chamber or something to allow the engine RPM to be higher than the throttle setting.
Randy )
)</font>
   / RPMs at Diesel Start-up #28
You must be right Soundguy, at least about my Kama. I usually start it with a smidgen of throttle trying to catch around 800rpms at start up. But the engine always roars to life before settling down, even when I forget to set the throttle for start up.
   / RPMs at Diesel Start-up #29
All governed mechanical injection pumps start with the rack (the thing that controls how much fuel is injected) in the full power position. It gets into that position when you shut the engine off. When you shut down, fuel is cut off and the engine starts slowing down. The governor doesn't know why the engine is slowing down, so it opens the rack to speed it back up. But since there is no fuel available, engine rpm continues to drop. The more engine rpm drops, the more the governor opens the rack until it is wide open. Thus the next time you start, you hear this little surge as the engine starts at full power and overshoots the rpm setting of the throttle, then settles down to the rpm commanded by the governor.
The throttle lever is not connected to the rack. It is connected to the governor. It tells the governor what rpm you want; the governor gives the engine enough fuel (via the rack) to maintain that rpm.
   / RPMs at Diesel Start-up #30
Flusher:
(Interesting forum name)
If you tractor wet stacks then you have an internal problem. Diesels with good comnpression and no ring problems won't wet stack unless they are idled for hours on end at very low ambient temperatures.
   / RPMs at Diesel Start-up #31
Jerry:
I just knew you lived in the boonies.....
Bet it's a four pole 1800 rpm unit. My Generac is the same way. Generac specifies 5-30 pure synthetic, they actually recommend Amsoil. My Generac starts at 3/4 throttle, runs 15 seconds and advances to full throttle and 15 seconds later assumes the load. When the transfer switch senses stability in the utility power, it switches out the genset and then the genset goes into a cool down mode at 3/4 no load throttle for 30 seconds. Love those electronics.
Our transfer switch is mounted in the basement stairwell and engagement is somewhat startling.
My employer has a Waukesha natural gas fueled, turbocharged genset. When the load transfers, the engine goes into a pre-lube cycle of 15 seconds whereas a 12 volt pump pressurizes the oil galleries and then it starts and goes to 1800 rpm.
   / RPMs at Diesel Start-up #32
</font><font color="blue" class="small">( Tota
George )</font> <font color="blue">nor could I figure out why they were wearing jackets.
</font> <font color="brown">Only in Florida do they wear jackets in the summer time. </font>
   / RPMs at Diesel Start-up #33
</font><font color="blue" class="small">( Only in Florida do they wear jackets in the summer time. )</font>
They who Brown? Not the typical scene in florida, sorry.
John
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2013 REITNOUER 48FT FLATBED TRAILER (A59905)
2013 REITNOUER...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A60429)
2016 CATERPILLAR...
