Backhoe RPM while using backhoe?
/ RPM while using backhoe? #21
"keeps the regen down"
What's "regen"?
Ain't got one!
Ain't gonna never have one either!
This is helpful. Thank you for your insight and posting to a LS Tractor thread. :thumbsup:
/ RPM while using backhoe? #22
Glad to know that you are so appreciative!
/ RPM while using backhoe? #23
For my XR4140H, I run most functions at RPM above 1500. Loader work higher for power, BH work also slightly higher for better control. So, when I hardly notice when I get a regen every 40-50 hours---just keep on working. I get a "feel" for how well the tractor can handle the task staying comfortable within my operator capability.
/ RPM while using backhoe? #24
Duh, I did not think about the larger HP tractors with emissions stuff. I am below the 25 HP, so no emissions system. In that case, definitely run at higher RPMs. I could see the lower RPMs and loading the engine clogging up stuff quick.
If my BX had emission control where I had to run a PTO speed+ all the time I would be looking at putting a restrictor in the power feed to the BH to slow down the movement. I have full pressure around 1700 RPM. Over 2000 RPM movement gets fast and jerky. Working around obstructions like I do a lot it gets to easy to smash stuff inadvertently.
Ron
/ RPM while using backhoe? #25
What speed do you all keep your tractor at while running your BH? My manual basically says it up to the operator, higher RPM means faster movement. Anyone have a sweet spot? I don稚 think pinning the RPMs is the best idea either. It痴 on a MT240HE.
Thanks all.
Here is a link to study . It shows a diesel to be most efficient when fully loaded and operated at the rpms where peak torque is available.
View attachment 639991View attachment 639992
ResearchGate
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
2013 Keystone Springdale Camper (A62613)
2013 Keystone...
Cattle Feeder (A65640)
2013 F150 (A62613)
2013 F150 (A62613)
