Backhoe RPM while using backhoe?
/ RPM while using backhoe? #21
"keeps the regen down"
What's "regen"?
Ain't got one!
Ain't gonna never have one either!
This is helpful. Thank you for your insight and posting to a LS Tractor thread. :thumbsup:
/ RPM while using backhoe? #22
Glad to know that you are so appreciative!
/ RPM while using backhoe? #23
For my XR4140H, I run most functions at RPM above 1500. Loader work higher for power, BH work also slightly higher for better control. So, when I hardly notice when I get a regen every 40-50 hours---just keep on working. I get a "feel" for how well the tractor can handle the task staying comfortable within my operator capability.
/ RPM while using backhoe? #24
Duh, I did not think about the larger HP tractors with emissions stuff. I am below the 25 HP, so no emissions system. In that case, definitely run at higher RPMs. I could see the lower RPMs and loading the engine clogging up stuff quick.
If my BX had emission control where I had to run a PTO speed+ all the time I would be looking at putting a restrictor in the power feed to the BH to slow down the movement. I have full pressure around 1700 RPM. Over 2000 RPM movement gets fast and jerky. Working around obstructions like I do a lot it gets to easy to smash stuff inadvertently.
Ron
/ RPM while using backhoe? #25
What speed do you all keep your tractor at while running your BH? My manual basically says it up to the operator, higher RPM means faster movement. Anyone have a sweet spot? I don稚 think pinning the RPMs is the best idea either. It痴 on a MT240HE.
Thanks all.
Here is a link to study . It shows a diesel to be most efficient when fully loaded and operated at the rpms where peak torque is available.
View attachment 639991View attachment 639992
ResearchGate
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
2008 Freightliner B2 Bus, VIN # 4UZABRDJ78CZ17948 (A61165)
2008 Freightliner...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
UNUSED KJ 12'X20' SINGLE GARAGE METAL SHED (A62131)
UNUSED KJ 12'X20'...
2023 Wolverine TBH-11-72 72in Bucket Skid Steer Attachment (A61567)
2023 Wolverine...
