Roundup?
/ Roundup? #1
Mark-in-Mo
I seem to have lost my booklet for the mix ratio. Does anyone know how many ounces to the gallon? Will be used to rework a food plot "starting over"
/ Roundup? #3
that sounds like a pretty strong mix. My label says 10ml per L for grass, and 15ml / L for woody weeds.
2.5 oz / gallon works out as a 2% mix (or 20ml / L) which is double the reccomended rate for killing grass, and 50% stronger than the woody "hard to kill " rate.
/ Roundup? #4
It depends on the concentration of your roundup... some you buy from the big box stores contain less than 20% glyphosate... the concentrated form is 41%. Assuming you have 41% (read the ingredients on the label), 2-3 oz. per gallon is right on.
/ Roundup?
Thanks guys, I thought I used about 2 pints per 15 gallons. My brain "aint" what it use to be.
/ Roundup? #6
I use 32 ounces of the 41% concentrate in my 15 Gallon ATV sprayer. That works out to roughly 2.1 oz. per gallon. Seems to always do the job.
/ Roundup? #7
If you use Roundup at a level of concentration less than recommended, It will still kill, it just takes a little longer.
/ Roundup? #8
It really depends. The ration you use in a spot sprayer is likely to be different than in a broadcast sprayer where you may be applying 20 gal/fluid per acre. Also, if you add surfactant or use a product with a built-in surfactant, they will be more efficient as the product adheres to the leaves much better.
You can find the bottle labels online. Assuming you are using a 41% glyphosate product, here is an example:
http://www.cdms.net/LDat/ld23M011.pdf
Hope this helps-
/ Roundup? #9
For grasses and weeds a 2% solution is sufficient using the 41% stuff. If you want to use (and I recommend it) a surfactant. A cheap liquid dish washing soap works good. My last suggestion and I'm sure you already know this is use the generic Roundup. It's a whole bunch cheaper.
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
Case TV380 (A62177)
Case TV380 (A62177)
2017 Chevrolet Express 3500 14FT Box Truck (A61573)
2017 Chevrolet...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
