Roundup + Monkeygrass = ??
/ Roundup + Monkeygrass = ?? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
About a week ago I sprayed some weeds & a bunch of Monkeygrass that the wife wanted rid of (after I broke my back going out to get it, transplant it and over the years, split it to propagate it :()
My presumption is because it might creep underground, you really want to kill it instead of just ripping it up. (perhaps that's wrong....I just know that I don't WANT to fool with ripping it up....again)
Sooooooooooo, I doused it pretty well with some Roundup.
Today about a week later, some of the grass/weeds growing in the driveway are turning a little yellow. The Monkeygrass, virtually all that I can see.... is laughing at me?
Will Roundup kill Monkeygrass and if so, do I need a stronger than normal solution?
/ Roundup + Monkeygrass = ?? #2
It will kill the monkey grass. It is best to do it when actively growing, like this time of year.
First off a few things to stack the deck in your favor. Use a stronger than 2.5% solution (which is what i purposely sray overtop of mine to kill the weeds out of it but not kill it, which is 3oz/gallon of 41% glyphosate concentrate), spray on a day that is in the 70s at least and make sure it had some water before. You prolly want to use something like 5% but for legallity you need to stay at the labled rate if you care to follow epa laws.
/ Roundup + Monkeygrass = ?? #3
Richard the straight 41% takes 7+ days to make stuff start looking dead and 2-4 weeks to kill to root level.
8 days ago I sprayed the church gravel parking lot and today the green stuff is starting to look dead. It rained 20 hours after I applied it at 32 oz. there 10 gallons of water. In the last 24 hours some plants that I though were not going to die are starting to look like they will die.
The fact it works at root level will be good for your moneygrass. It just takes 2-4 weeks to work at that level. The fact that it is not a burn down type chemical gives it time to get the chemical to the roots. After the 20 hour period it rained non stop for 6 days.
I plan to respray after 30 days if new stuff sprouts.
OK, thanks.
I'll give this more time to work before hitting the panic button. I'll spray again if/as needed. I'm expecting new sprouts so was planning on spraying again anyway.
I did up the dosage a little bit. When mixing, I always round up a tad. Perhaps not enough to matter but I figure I'd always rather have the correct amount plus a tad rather than the correct amount minus a tad.
/ Roundup + Monkeygrass = ?? #5
Yesterday was day nine since I sprayed at church and the results are just started to be really easy to see at a glance. It has rained 7 of those 9 days (did get 20 hours before the first rain however) and it kept right on working.
Coming back to the house I was just spraying up the side ditch to empy the tank (mounted on the golf cart) and yesterday it is clear where I ran out. :D
I too round up on usage. I used a quart per 10 gallons or 3.2 oz per gallon instead of 3 oz of 41% of generic Round-Up. To kill brush the mix has to be increased but I do not have that in front of me.
At $20 a gallon this means it cost me $.50 per gallon of mix but that will spray a heck of lot. I do find more to spray with the 12v tank sprayer than with the two gallon hand tank. :laughing:
/ Roundup + Monkeygrass = ?? #6
I sprayed some weeds with "Roundup" a month or so ago. For the taller weeds it took at least two weeks for them to brown out an die. The short weeds, same variety, still took a good week to turn brown.
The taller weeds were green. Then one day they just were brown. FINALLY.
I have to go back and spray again for the Nut grass that spreads underground. That stuff is a pain.
Later,
Dan
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
2018 John Deere 333G Track Loader (A63111)
2018 John Deere...
2015 Honda Accord Sedan (A61574)
2015 Honda Accord...
2022 EZ-GO ELITE...
