Rounded off drain plug
/ Rounded off drain plug #961
I do not think there has been a consensus that it is going to be a pipe wrench. Kando should wait until everyone in TBN agrees to a plan.... oh wait... are they calling it a playbook these days?
:confused3:
Thank you!
It's the 21st Century and pipe wrenches (quality or not... although probably inherited from a deceased [though much loved] maternal/paternal senior/grand/great-grand relative) are the stuff of Luddites.
I like the Knipex solution... indeed, I've priced one at A$85 at TotalTools in Launeston and am thinking of swinging by there a week Monday to have a wee boo.
/ Rounded off drain plug #962
Thank you!
Pipe wrenches still have no replacement and I don’t know what you have against them.
/ Rounded off drain plug #963
Thank you!
While your there, buy yourself a pipe wrench.
/ Rounded off drain plug #967
Didn't somebody mention a Monkey Wrench and footballs? :monkey::football::monkey::football::monkey::football::monkey::football:
(Isn't a Monkey Wrench just a pipe wrench without dentures?)
/ Rounded off drain plug #968
. BYOPR. (Bring your own pipe wrench.)
Edit.
My apologies for not being more INCLUSIVE
SB: BYOTOC. (Bring......Tool of Choice)
/ Rounded off drain plug #969
Monkey wrench doesn't have a pivoting moving jaw that tightens when force is applied, like a pipe wrench does.
Bruce
/ Rounded off drain plug #970
Here’s how hard a pipe wrench will bite. This same pipe wrench which is by no ones standard a quality tool and has buggered up teeth easily holds my weight turning against a floor jack axel. IMG_0829.JPGIMG_0831.JPGIMG_0830.JPG
/ Rounded off drain plug #971
You do understand the concept of tongue-in-cheek humour, don't you?
Same as my response to Big Barn. As was Big Barn's comment that I responded to.
Lighten up.
bcp - I thought the wrench with dentures part gave suggested "tongue in cheek"
/ Rounded off drain plug #972
I repeated the same test with my knipex and they also passed. Then I decided to do it again with a pair of vice grips which while I was standing straight down they also held. Then I got sideways a little and knocked them off. I’m pretty sure this less than perfect twisting force and instead pulling the wrench down is probably the OPs problem. IMG_0832.JPGIMG_0833.JPG
/ Rounded off drain plug #973
Since I’m still board how should we over tighten and strip this pipe plug? My Klein adjustable wrench seems to me holding like a champ. IMG_0834.JPGIMG_0836.JPG
/ Rounded off drain plug #974
Hereç—´ how hard a pipe wrench will bite. This same pipe wrench which is by no ones standard a quality tool and has buggered up teeth -------------
And you adjusted it correctly, note the gap where I put the arrows:
Here is a side view from their Website showing the same thing:
/ Rounded off drain plug #975
I think the pipe wrench jaws had actually bottomed against the head after crushing the pipe which is not optimal. They should be like this. Notice the gap which leaves room to grip tighter. IMG_0839.JPG
/ Rounded off drain plug #976
And it must not be my day to strip a plug. I grabbed what I thought would be a sure fire way so strip it which was a 12 point socket on a 24” breaker bar. It drove the plug all the way through the taper at which point it wasn’t getting tighter and then backed it out. IMG_0838.JPG
/ Rounded off drain plug #977
Since I知 still board how should we over tighten and strip this pipe plug? My Klein adjustable wrench seems to me holding like a champ.
First thing would be to turn it over to the recommended position for tightening:
Less likley to break the adjustable jaw.
Then use a 3' long cheater pipe on it. :D
/ Rounded off drain plug #978
Here is my CHANNELLOCK 410 I purchased over 30 years ago which now has less than perfect teeth. (( the plier wrench, not me)
It didn’t slip with my full weight on it.
/ Rounded off drain plug #979
We'd better back off with the innocuous comments, if we want the 1000th post to be Kando telling us that he got the plug out. ;)
2016 Ford Transit 350 Cargo Van (A61573)
2016 Ford Transit...
Landa PGDC5-3500 (A64119)
Landa PGDC5-3500...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
