Rounded off drain plug
/ Rounded off drain plug #361
My guess is that most tractor owners in the US change oil when it's hot and the hotter the better.
What shape plugs do most tractors have - tapered or straight?
/ Rounded off drain plug #362
Most modern tractors are straight thread with o ring or washers of some sort to seal. Some still have a few tapered plugs here and there. Most gear boxes still use taper threads, and as you said , just need to know how tight is tight when servicing them, no need to have them gorilla tight. I usually drain my oils when the unit has set a while and oil has drained down and settled, just my preference.
/ Rounded off drain plug #364
this is the only thing that should be used on a square drive drain plug. Cheap 1/4", 3/8", and 1/2" Square Box Wrenches photo8.jpg using vise grips, pliers, or pipe wrenches, or even open ended wrenches will eventually round off the square nut..
/ Rounded off drain plug #365
They also have socket sets for square plugs.
/ Rounded off drain plug #368
I also have several 8 point sockets for square plugs too. Most tool brands have them.
/ Rounded off drain plug #369
I would not recommend 8 point sockets for square plugs, as they would have less contact points, and could strip the plug if a lot of pressure is needed to remove it.. Thanks for the link to the four point sockets though, they are very difficult to find at a decent price!..
/ Rounded off drain plug #370
I've learned something today. If I ever ran across a square drive plug, I think a 3/8, 1/2, or 3/4 inch drive extension fit and I hoped they were all like that.
/ Rounded off drain plug #371
Well .... you did it!! 38 pages!!
/ Rounded off drain plug #372
Who did what?
/ Rounded off drain plug #373
I see more pages in our future...
/ Rounded off drain plug #375
This is #376. How many is the target? :)
/ Rounded off drain plug #377
They work just fine, just have to be smarter than the tools your working with.
/ Rounded off drain plug #378
Thank you for the heads up. I had no idea and sure could use that set.
Your welcome, they are handy for sure. There are several different brands and price ranges , just have to search around and find what you like.
/ Rounded off drain plug #379
/ Rounded off drain plug #380
Not sure what that’s supposed to mean. Pretty simple fact that a 4 point head in a 4 point socket takes more before it strips vs 8 point. Let me guess. A 12 point works just as good as 6 point it’s just operator error?
2015 Nisan Altima S Sedan (A61574)
2015 Nisan Altima...
Caterpillar 416/426/428/436/438B Backhoe Service Manual (A63117)
Caterpillar...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
COMBINATION ELECTRICAL & COOLING SYSTEM (A64281)
COMBINATION...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
