lilranch2001
Super Member
- Joined
- Nov 25, 2009
- Messages
- 9,040
- Tractor
- Bobcat CT 235
The gubberment says it is!
Now we have the underlying cause; rusted from the inside jamming up the threads. Oil floats on top of water, and the drain is the low point; so,wouldn't take much free water to create rust especially with a good dose of the products of combustion which are acidic. Kando didn't have a ghost of a chance on this one.
--------------------------------Ron
More ammunition for us who promote drilling it out.
A pipe wrench grips much tighter vice grips. Had the op skipped the vice grips and the channel locks and went straight to the pipe wrench and he knew how to use a pipe wrench the plug would be out already.
So instead of getting the plug out, he first needs to bung it up more? I have yet to see a nut or bolt which actually "rounds" when the corners wear off. Usually they become more oval shaped.And just for the record, the more "rounded off" the work object is the better the pipe wrench is going to work. After all it works perfectly on round pipe and round pipe fittings now doesn't it?
Since we have to round it off first, why not try the one tool which he hasn't used? If nothing else, it will make the plug so that the pipe wrench works.^^^^^^ What he said !!!
"with a good dose of the products of combustion which are acidic." In the transmission?[/Q
Cut us old guys some slack; we have a hard time remembering all the stuff we read through 1775 posts. Who knows, the additives to transmission fluids may add acid to the water also or is Kando's tractor so old it uses 30 or 40 weight motor oil for transmission oil. Some of the old farm tractors used the motor oil sump as source for hydraulic fluid. Helped a guy once that had one of those. He claimed that the thicker the oil got the better the 3 point worked. He had a FEL for it but never put it on the trator.
Kando, we are half way through the Memorial Day weekend. Times a wastin :drillsergeant:
You guys are just impatient!
Don't RUSH things....
