Rounded off drain plug
/ Rounded off drain plug #1,481
This was posted by the OP long ago, not sure which post exactly. It's a large file size, so I won't repost it, just the link. Look at this picture closely, then tell us how you'll get the punch and bit lined up square enough to do what you suggest.
https://www.tractorbynet.com/forums...018-rounded-off-drain-plug-transdrainplug-jpg
Thank you for keeping track. By employing such discipline we would have been able to limit the thread to 30 or 40 posts having real pertinence.
/ Rounded off drain plug #1,482
I actually had this kind of fun before- but it was the bronze drain plug in the bilge of a boat. I had surgery and had not removed the plug like I normally did. By the time I got to it, I had to break the ice and reach down into a foot of water below that to a plug that was out of sight and had to be removed by feel. That is when I really appreciated my brilliant decision in the spring to screw the plug in one more time with the rounded off head. "I'll worry about it later."
Finding something by feel doesn't work too well when you can't feel your hands at all.
/ Rounded off drain plug #1,483
I personally do not like fluid extractors for the simple reason that it leaves a layer of sludge in the bottom of the crank case.
Removing the plug at the lowest point allows one to remove almost all sludge.
/ Rounded off drain plug #1,484
It is absolutely preferable to drain rather than extract- unfortuantely, it can't be done with a lot of inboard boats short of pulling the engine.
/ Rounded off drain plug #1,485
A lot of marine engines have riser hoses that are plugged and vertical when running but can be bent down and opened to drain into a bilge or connected to a pump etc...some land machines use the same type of drain...
/ Rounded off drain plug #1,486
Didn't he extract the oil and do the change long ago? The point in getting the plug out is to flush the engine of any sludge or contaminates that may be lurking in the pan.
Tranny drain plug.
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
