Rough running engine
/ Rough running engine #1
dsolsbery
I have a Hinomoto E 222 with a 3 cylinder diesel engine. For a while now it's been running rough like the engine is flooding, and seems to smoke quite a bit. I've heard that the fuel injector pump can be timed, and if it's out of timing, would it cause the problem I'm having? If anyone one has done this before, would you mind filling me in on how to do it?
Is there anything else that can cause these symptoms?
Thanks in advance,
Dennis
/ Rough running engine #2
The injector pump can't get out of time unless it is removed. You could have low compression or coolant mixing with fuel either of which can be caused by a bad head gasket or cracked head.
Eugene
/ Rough running engine #3
Have you changed air or fuel filters lately? I'd make sure they are clean.
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
211298 (A62131)
211298 (A62131)
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
