Tiller Rotary Tillers - Sicma Phoenix vs Ansung Terra Force
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #31
thanks-thats what i needed to know.i noticed the yjr074 has only 42 blades while the sicma t10 74ge has 54. will they till the same or is more tines better?
More is not always better. The Terraforce has them spaced in a rotary cutter pattern and the tip length is a bit longer. It will also till 8" vs 7 and the unit is 200 lb heavier. If you can, do a side by side comparison on how they are made.. Ill try and measure mine tomorrow if they will help you.
PS - these folks have a good price on the YJR074. McGee Farm Equipment, Inc.
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #32
thanks i would really appreciate that
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #33
after looking at pictures of the yjr74- man that is a beast.do you think my l3800 with 38 hp and 31pto will handle it?
In my research, the only advantage I noticed with the Sicma was the sight glass for the side gear oil. The advantages of the Terra Force outweighed this by having a bolt on second plate for the skids and spring tail gate versus chain on the Sicma.
BTW-That's where I bought mine from. Very good experience dealing with them! BTW-You can specify red or orange for the colors.
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #35
one other advantage is the sicma is 350 dollars cheaper at this place,but the terra force is 200lbs heavier.i also found the sicma 520 dollars cheaper at another site.i can afford either one but i like to save whenever it is feasible.
I don't feel you will go wrong with either brand. I would pull the trigger on what you feel is best for you and not look back. :)
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #37
MY Bobcat CT235 is 34 HP and 26.5 at the PTO. However it is hydrostatic, so I can slow down as much as needed when it digs in. It will load me down somewhat when I am at full depth in wet stuff, but I can feather the speed and pull through easily. I have never had it stall the tractor or slip the units slip clutch. For deep digging I run in low range and just take my time and let it work.
However I did demo the unit on my tractor before buying.
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #38
thanks-mine is a hydro also so i should be ok.
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #39
Measured the distance to the Cat I inner and outer flanges. It's 26.5" between the inside faces, and 31.5" between the outer faces. The Cat 2 slot starts at 32.5"
I can easily hook up with my Bobcat with plenty of room to spare between the outer points on the lift arms. Just check you tractor, it should work. One question - what is you lift capacity as this beast weighs 920 lbs.
Good luck with your choice.
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #40
my lift cap. is 1435 @24inches ,is this good enough of a safety factor?i dont want to damage my tractor if i can help it.
2011 MERCEDES-BENZ E-Class (A56859)
2011 MERCEDES-BENZ...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
JCT 72" Skid Steer Rotary Brush Cutter, Asset# 68 (A59076)
JCT 72" Skid Steer...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
