Tiller Rotary Tillers - Sicma Phoenix vs Ansung Terra Force
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #21
PS one tip - take a wrench and check all the bolts, and do it again after a bit of use. On mine I find one that needs snugging up once in a while.
I second this tip. I did it on mine. Didn't find anything really loose, but it's worth a few minutes to do it.
Congrats. You're going to like it. What was your cost delivered?
Right around $3450 delivered to freight terminal. I had two other items that factored into the freight, so I am not 100% on the exact amount. Price before shipping was $3187.50.
Thanks for the pics. It looks like all you have to do is the PTO assembly, and probably add gearbox oil.
Looks great.
Yup, and top link assembly as well as kick stand. No biggie...will enjoy doing it.
Thanks for the tips on the loose bolts. Will check them all before it hits the garden.
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #25
That seems reasonable. My 74" was right at $2500 picked up at my local dealer (30 miles away).
I went back and forth between the 74 and 80 and wondered why so much of a price bump for 6 inches of tilling width. From the best I could tell, the main difference was that the tube that bottom clevis lift points are welded to extends the width of the frame on the 80 versus stopping at the lift points on the 74. I am sure the 74 is structurally sound, but I just felt safer going with the beefier hitch on the 80. Plus, the total width of my rear tires is 73.5 inches, and I liked the 80 to make sure I covered my tracks. ;)
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #27
i am also looking at the yjr74 but my tractor needs to have the hitch 26 or so inches wide or narrower and the hitch on the terra force looks like it is too wide.am i missing something?i really like the extra weight and spring loaded tailgate.
Maybe someone who has the YJR74 can measure theirs to be sure, but I do know the 80 is Cat II only, and the 74 is Cat I or II. The 74 has clevises for both widths. Cat I is standard 26 inches wide.
For those interested, I found out about the 3 pt strap to the gearbox change to the box frame on top of the Ansung tiller. I know this applies to the YJR 80/90 models, but not so sure on the others. There are actually 4 generations of these tillers, and the first two included the 3rd link strap design attaching directly to the top of the gear box. They changed it on the third generation to the 3rd link box frame and have kept it for the 4th gen. To check your generation of YJR 80/90 use the following link to check the serial number ranges at the bottom of page 3.
http://www.ansungusa.com/pdf/PartsManuals/RT-GD-YJR080-090.pdf
Here is the link for the YJR74 to check your generation...
http://www.ansungusa.com/pdf/PartsManuals/RT-GD-YJR074.pdf
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #30
thanks-thats what i needed to know.i noticed the yjr074 has only 42 blades while the sicma t10 74ge has 54. will they till the same or is more tines better?
2022 CARGO CRAFT ,INC. KNIGHT FIRE SUPPRESSION (A55745)
2022 CARGO CRAFT...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A57024)
GMC 3500 Extended...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A53422)
2012 Chevrolet...
Cushman Cart (A55853)
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
Red Military Truck (A53422)
Red Military Truck...
