WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 12,529
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
An 3Ø motor will generally run fine on single phase, the primary penalties being:When I'm working the H/V milling machine, I always leave the power table feed and the suds pump motors running. The spindle motor starts so much more readily.
Perhaps that is why "balance capacitors" are a non issue for this use.
1. Vibration
2. Efficiency
3. Horsepower
If you don't mind giving up a bit of each, and you have some way to get the thing started, then it can work. Of course, balancing capacitors can offer a huge improvement on all three of the above points. The only catch is that the ideal balance capacitor arrangement varies with how hard you load down the motor while cutting.
Think of any induction motor, whether three phase or single phase, as a bicycle that's missing one pedal or a single-cylinder engine. Once you get the thing moving, inertia can bring the pedal or piston back to top dead center, where you can push again to keep moving. Getting the thing started is the job of the start winding in a single-phase induction motor, which is usually wound with a smaller wire (more resistance) and loaded with a bit of capacitance, to put it out of phase with the run winding. It's the second piston on a 90 degree crank shaft.
Three phase motors don't need a start winding, because they already have three windings, at 120° phase relationships. A 3-piston engine will never be stuck with all pistons ahead of top dead center, and likewise, a 3-phase motor always has at least one phase developing torque in the desired direction.
