Buying Advice rotary cutter
   / rotary cutter #21
not sure why changing blades would be a issue...
the brush cutters are about all the same to service. Most of us are running older brush cutters and dont sharpen them. My cutting edge is quite rounded off but will still do a great job of grooming a entry road around the pasture. If you are looking for a consistant golf course type cut then maybe go with a flail mower.
To change the blades a strong battery or air impact makes it a one man job.
A used one around here in decent condition wpuld run around 500-800 dollars and up.
   / rotary cutter
well someone has to hold the bolt up so the nut can be started... and one mower i had the pan was included in holding things up..
   / rotary cutter #23
hi folks..gravelman here..im thinking of buying a Kodiak 5' HD rotary cutter... any advice or info out there. I need an easy to change blade cutter...getting too old to be climbing under stuff. thanks
I've owned a bunch of rotary cutters and the older I get the harder it is to change the blades. My latest one is a Landpride RCR1860 and so far I have been very pleased with it. Slip clutch, decent gearbox, top access hole for blade bolts, and is very smooth. (Besides that the paint matches my Kubota) Probably not as HD as the Kodiak though. Good luck with the one you get.
PS: I'm too old to be climbing under stuff too.
   / rotary cutter #24
If you're not gonna use it that much (as you said) then you really don't have to worry too much about changing the blades. I have an old Bush Hog (very old) and I've been using it since I bought it used 6 years ago. I brush cut about 50 acres at least 4 times/year and I've never sharpened or changed the blades in that time and it still cuts just fine. Like Rebeldad1 said, most of us run older brush hogs without sharpening them, and for pasture work, they will cut just fine.
And from what I've heard, Kodiak makes a quality cutter.
   / rotary cutter #25
It's not the climbing under - it's the getting back out and up.
   / rotary cutter
ahh that is the tough part...when i mentioned another pair of hands...it was to help me up !!!!!!!!!!!!!! The mowing you do must be free of rocks and debris...not so where i am.. you would not recognize the blades when it is time to sharpen... but i have most of the rocks rounded off now...
   / rotary cutter #27
I like loading the tractor with brush mower on the trailer and sitting on a stool to sharpen the blades with a 4 inch grinder. I do make sure that it is well blocked if I need to raise it a little while on the trailer, and throw a chain to insure the tractor doesn't move. I leave the mower extending out past the end of the trailer.
For your blade removal, if your impact isn't strong enough to remove the bolts, a torque multiplier is a great investment. Usually pretty pricey, but occasionally a good deal can be found if you are diligent in your search.
David from jax
   / rotary cutter
That is a great idea...thank you. i use a breaker bar to start the nuts.. then an old fashioned socket..
   / rotary cutter #29
David from jax
That sounds like a plan. I'm gonna try that method next time. I used to have two bush hogs and a 50 hp tractor. My old one I only used to cut brush and small trees and I never sharpened it. The other one I kept the blades sharp and used it for smooth grass cutting. When I sold my big tractor and both 6' bush hogs I just have the one and use it 99% of the time to cut grass so I like to keep the blades sharp. I don't have rocks thank goodness.
   / rotary cutter #30
Well I guess we know why they call you "gravelman" now. Lol.
I'm of the "Don't sharpen" camp. I've never had mine off or sharpened them (3 years), but I mostly mow pastures with no rocks. So I'm lucky there. I do have one large field I mow about once a year or two that has many hidden rocks in it, up to watermelon sized. I've hit a few for sure, but my blades still look fine. Makes a **** of a racket though, and puts some new dents in the deck, but it (so far) keeps cutting along. Hard to see them watermelon sized rocks when the grass is over your hood. But you sure know it when you find one.
:laughing:
17101 (A55851)
17101 (A55851)
2012 CHEVROLET SILVERADO 1500 (A58214)
2012 CHEVROLET...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
