Mowing Rotary cutter with dual blades
   / Rotary cutter with dual blades #11
Right click the PDF link and select "save link as" and select the save point to someplace you can find the file, such as your desktop.
   / Rotary cutter with dual blades #13
It should work just like an image file.
If you go down to the "quick Reply" box, then click on "Go Advanced" there will be a "Manage Attachments" button below the text box, which indicates PDF is a valid file to attach.
The little icons above the "Quick Reply" may not work for a PDF.
Bruce
   / Rotary cutter with dual blades #15
I'm relatively sure when I right click on a PDF on JD parts schematic no "save as link" comes up. I'll look again. Thanks,Jim
   / Rotary cutter with dual blades #16
Sorry, sometimes I assume everybody's a Firefox user, IE users would select "Save Target As"
   / Rotary cutter with dual blades #17
I use Firefox.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A58017)
2014 INTERNATIONAL...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
