Mowing Rotary cutter with dual blades
   / Rotary cutter with dual blades #11
Right click the PDF link and select "save link as" and select the save point to someplace you can find the file, such as your desktop.
   / Rotary cutter with dual blades #13
It should work just like an image file.
If you go down to the "quick Reply" box, then click on "Go Advanced" there will be a "Manage Attachments" button below the text box, which indicates PDF is a valid file to attach.
The little icons above the "Quick Reply" may not work for a PDF.
Bruce
   / Rotary cutter with dual blades #15
I'm relatively sure when I right click on a PDF on JD parts schematic no "save as link" comes up. I'll look again. Thanks,Jim
   / Rotary cutter with dual blades #16
Sorry, sometimes I assume everybody's a Firefox user, IE users would select "Save Target As"
   / Rotary cutter with dual blades #17
I use Firefox.
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
Zero Turn Mower (A55853)
Zero Turn Mower...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A58017)
2005 INTERNATIONAL...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
2008 International Bucket Truck (A55973)
2008 International...
utv cart Honda (A56857)
utv cart Honda...
